@Pedro_Liberal
I also trying to use Espresense but it seems not accurate enough for me to trigger event.
Situation:
At initial, my iphone or watch close the ESP32 around 0.2m. Then walk away it to 1m just in 1 second.
But the response show that the distance still keep in 0.2m, 0.2xm, 0.2xm, 0.3m…1m (it takes around 8-20s to adjust it and finally it get the correct distance)
Observation:
- The rssi(-32) > rssi@1m(-65) (e.g ) when my device near the ESP around 0.2m
- The rssi(-65) ~= rssi@1m(-65) (e.g ) when my device move away from the ESP around 1m (change it significantly )
- The raw(0.9~1.9) when my device near the ESP around 1m (change it significantly but unstable)
Conclusion/ Question/ Problem:
rssi
or raw
can reflect the latest status of my device (although I don’t know what is “raw”, i think it likely similar to distance but it is unstable). And It is strange that why “distance” can not reflect the current status and it needs time to change it slowly (0.2 → 0.2x, 0.3 → 0.3x → …-> 1). Suppose the formula of distance is base on rssi.
do you have such problem or anything I need to config it?
10:19:52
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-34,"raw":0.13,"distance":0.15,"speed":-0.00,"mac":"430e33182fc7","interval":492}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-41,"raw":0.21,"distance":0.15,"speed":0.00,"mac":"430e33182fc7","interval":491}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-52,"raw":0.43,"distance":0.15,"speed":0.01,"mac":"430e33182fc7","interval":491}
10:19:54
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-72,"raw":1.58,"distance":0.16,"speed":0.06,"mac":"430e33182fc7","interval":491}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-72,"raw":1.58,"distance":0.20,"speed":0.09,"mac":"430e33182fc7","interval":491}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-69,"raw":1.30,"distance":0.26,"speed":0.06,"mac":"430e33182fc7","interval":489}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-70,"raw":1.39,"distance":0.28,"speed":0.06,"mac":"430e33182fc7","interval":492}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-66,"raw":1.07,"distance":0.36,"speed":0.06,"mac":"430e33182fc7","interval":490}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-64,"raw":0.94,"distance":0.37,"speed":0.04,"mac":"430e33182fc7","interval":491}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-63,"raw":0.88,"distance":0.40,"speed":0.03,"mac":"430e33182fc7","interval":493}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-66,"raw":1.07,"distance":0.52,"speed":0.04,"mac":"430e33182fc7","interval":492}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-68,"raw":1.22,"distance":0.53,"speed":0.04,"mac":"430e33182fc7","interval":492}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-78,"raw":2.35,"distance":0.61,"speed":0.07,"mac":"430e33182fc7","interval":494}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-74,"raw":1.81,"distance":0.70,"speed":0.09,"mac":"430e33182fc7","interval":497}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-74,"raw":1.81,"distance":0.81,"speed":0.06,"mac":"430e33182fc7","interval":495}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-69,"raw":1.30,"distance":0.85,"speed":0.03,"mac":"430e33182fc7","interval":496}
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-69,"raw":1.30,"distance":0.90,"speed":0.02,"mac":"430e33182fc7","interval":498}
10:20:13
{"id":"irk:____","disc":"071897c6e5","idType":200,"rssi@1m":-65,"rssi":-75,"raw":1.93,"distance":1.00,"speed":0.05,"mac":"430e33182fc7","interval":496}
