Border width or line width of switch chart
Is there a way to increase the line thickness or the border width in the following example of a chart of a switch or contact? Short spikes are very poorly visible.
chartType: “”
period: D
label: Haustuere_Schloss + 1
slots:
grid:
- component: oh-chart-grid
includeLabels: true
xAxis:
- component: oh-time-axis
gridIndex: 0
yAxis:
- component: oh-value-axis
gridIndex: 0
series:
- component: oh-time-series
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: line
color: blue
areaStyle: {}
slots:
markArea:
- component: oh-mark-area
item: Haustuere_Schloss
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: line
color: red
areaStyle: {}
slots:
markArea:
item: Haustuere_Sensor_Contact
tooltip:
- component: oh-chart-tooltip
confine: true
smartFormatter: true
legend:
- component: oh-chart-legend
bottom: 3
type: scroll
dataZoom:
- component: oh-chart-datazoom
type: inside
Quick hint: Your post’s code will always be easier for others to read if you use code fences:
Code here
The charts use apache eCharts so you can always check that documentation to try and find options. It’s very comprehensive and well laid out (though sometimes slightly opaque):
In this case, you need the lineStyle object to set the width so it should, I think, look something like this:
    gridIndex: 0
    xAxisIndex: 0
    yAxisIndex: 0
    type: line
    color: blue
    lineStyle:     <-----------
      width: 2     <-----------
    areaStyle: {}
  slots:
    markArea:
Thanks for the answer and the tip with the fences!
Unfortunately, lineStyle and width do not make any change. Is it possible that only the area is marked and the border (line) is not displayed at all? The Echarts docu did not help me.
  chartType: ""
  period: D
slots:
  grid:
        includeLabels: true
  xAxis:
        gridIndex: 0
  yAxis:
        gridIndex: 0
  series:
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        color: blue
        lineStyle:
          width: 10
        areaStyle: {}
      slots:
        markArea:
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        color: red
        lineStyle:
          width: 10
        areaStyle: {}
      slots:
        markArea:
        gridIndex: 0
        xAxisIndex: 0
        yAxisIndex: 0
        type: line
        item: Haustuere_Sensor_Contact_Numeric
  tooltip:
        confine: true
  legend:
        bottom: 3
        type: scroll
  dataZoom:
        type: inside
Yep, you’re absolutely right. I completely missed that. Because the boolean type item automatically use a markarea, the data is not being drawn as a line. In the eCharts docs you’ll see there’s also a section of markArea and in this case you modify that using the itemStyle object. So, if you want to draw a border around your marked areas it would look like this:
    gridIndex: 0
    xAxisIndex: 0
    yAxisIndex: 0
    type: line
    color: blue
    areaStyle: {}
  slots:
    markArea:
          itemStyle:                      <--------
            borderWidth: 2                <--------
All the other markArea itemStyle options listed are also available.
Works perfectly, thank you!
