I absolutely love the bose binding!
So far it’s working nicely for my Soundtouch300 and Soundtouch10.
But I found a weird behavior:
When I turn on my SoundTouch300 to AUX channel, openHAB won’t show Power/OperationMode correctly.
But, as soon as I go to channel Spotify or Bluetooth, I see the correct Power state for both (I changed volume manually):
Here is my setup:
bose.things:
bosesoundtouch:device:300 @ "LivingRoom" [ host="192.168.178.22", macAddress="xxxx" ]
bose.items:
Switch BOSE_SoundTouch300Power "Bose SoundTouch 300 Power" <switch> {channel="bosesoundtouch:device:300:power"}
sitemap
Switch item=BOSE_SoundTouch300Power label="SoundTouch 300 [%s]"
logs when turning on SoundTouch300 in AUX channel:
2020-05-17 12:04:05.937 [ome.event.ItemCommandEvent] - Item 'BOSE_SoundTouch300Power' received command ON
2020-05-17 12:04:05.951 [nt.ItemStatePredictedEvent] - BOSE_SoundTouch300Power predicted to become ON
2020-05-17 12:04:05.977 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300Power changed from OFF to ON
2020-05-17 12:04:05.991 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300Power changed from ON to OFF
2020-05-17 12:04:06.555 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300NowPlayingItemName changed from to NULL
2020-05-17 12:04:06.562 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300NowPlayingItemName changed from NULL to
2020-05-17 12:04:06.564 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300PlayerControl changed from PAUSE to PLAY
logs when turning off the soundbar
2020-05-17 12:14:31.129 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300NowPlayingItemName changed from to NULL
2020-05-17 12:14:31.132 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300NowPlayingItemName changed from NULL to
2020-05-17 12:14:31.133 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300OperationMode changed from SPOTIFY to STANDBY
2020-05-17 12:14:31.134 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300Power changed from ON to OFF
2020-05-17 12:14:31.135 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300PlayerControl changed from PLAY to PAUSE
2020-05-17 12:14:31.248 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300NowPlayingItemName changed from to NULL
2020-05-17 12:14:31.249 [vent.ItemStateChangedEvent] - BOSE_SoundTouch300NowPlayingItemName changed from NULL to
Question:
Is it possible to get the correct binding for AUX channel for power and operation mode state?
Thanks!
Peter
