Hello! I have a problem with the work of Xiaomi Bridge. Il.p normally connects and works for some time (and sensors too), but after an hour or more it goes offline.
To return it online, you must restart OpenHub or turn off/on the Thing in PaperUI.
heartbeat every 10 seconds in log:
2018-12-31 02:27:46.269 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-2946,5,main] waiting for data on port 9898
2018-12-31 02:27:56.234 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.1.15:4321 on Port 9898
2018-12-31 02:27:56.236 [TRACE] [internal.handler.XiaomiBridgeHandler] - Received message {"cmd":"heartbeat","model":"gateway","sid":"04cf8c744c39","short_id":"0","token":"BIMZCMeHa1XixHt7","data":"{\"ip\":\"192.168.1.15\"}"}
2018-12-31 02:27:56.240 [TRACE] [internal.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 04cf8c744c39
2018-12-31 02:27:56.246 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Cancelled running timer
2018-12-31 02:27:56.249 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"heartbeat","model":"gateway","sid":"04cf8c744c39","short_id":"0","token":"BIMZCMeHa1XixHt7","data":"{\"ip\":\"192.168.1.15\"}"}
2018-12-31 02:27:56.253 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-12-31 02:27:56.255 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-2946,5,main] waiting for data on port 9898
Last heartbeat and bridge goes offline:
018-12-31 02:28:06.219 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.1.15:4321 on Port 9898
2018-12-31 02:28:06.222 [TRACE] [internal.handler.XiaomiBridgeHandler] - Received message {"cmd":"heartbeat","model":"gateway","sid":"04cf8c744c39","short_id":"0","token":"s3CdI0MhyLiaw5Lj","data":"{\"ip\":\"192.168.1.15\"}"}
2018-12-31 02:28:06.225 [TRACE] [internal.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 04cf8c744c39
2018-12-31 02:28:06.231 [DEBUG] [internal.handler.XiaomiBridgeHandler] - Cancelled running timer
2018-12-31 02:28:06.234 [DEBUG] [rnal.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"heartbeat","model":"gateway","sid":"04cf8c744c39","short_id":"0","token":"s3CdI0MhyLiaw5Lj","data":"{\"ip\":\"192.168.1.15\"}"}
2018-12-31 02:28:06.238 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-12-31 02:28:06.240 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-2946,5,main] waiting for data on port 9898
2018-12-31 02:33:06.249 [hingStatusInfoChangedEvent] - 'mihome:bridge:04cf8c744c39' changed from ONLINE to OFFLINE
2018-12-31 02:33:06.264 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d000273cd11' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-12-31 02:33:06.272 [hingStatusInfoChangedEvent] - 'mihome:gateway:4cf8c744c39' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-12-31 02:33:06.278 [hingStatusInfoChangedEvent] - 'mihome:sensor_magnet_aq2:158d000276c39f' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-12-31 02:33:06.283 [hingStatusInfoChangedEvent] - 'mihome:86sw2:158d0002b49c8a' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-12-31 02:33:06.293 [hingStatusInfoChangedEvent] - 'mihome:sensor_plug:158d0001e8838c' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-12-31 02:33:06.299 [hingStatusInfoChangedEvent] - 'mihome:sensor_motion_aq2:158d0002b7641a' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-12-31 02:33:06.306 [hingStatusInfoChangedEvent] - 'mihome:gateway:04cf8c744c39' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
Bridge info:
Version code:213
网关ID:130080011
Zigbee通道:25
网关信息:
{"life":444998,"cfg_time":0,"token":"18fd8f1ac717e6a28fea65955d8ffef1","mac":"04:CF:??:??:??:??","fw_ver":"1.4.1_161","hw_ver":"MW300","model":"lumi.gateway.v3","mcu_fw_ver":"0143","wifi_fw_ver":"SD878x-14.76.36.p84-702.1.0-WM",
"ap":{"rssi":-40,"ssid":"Fig_Vam","bssid":"bssid"},
"netif":"localIp":"192.168.1.15","mask":"255.255.255.0",
"gw":"192.168.1.1","gw_mac":"mac"},
"mmfree":166000,"ot":"ott",
"otu_stat":[438,404,320,29,239,1069],"ott_stat":[117,4,444,963]}
子设备信息:
[{"model":"lumi.plug.v1","did":"lumi.158d0001e8838c","name":"Mi Smart Plug"},
{"model":"lumi.weather.v1","did":"lumi.158d000273cd11","name":"Temp"},
{"model":"lumi.sensor_magnet.aq2","did":"lumi.158d000276c39f","name":"Aqara Door and Window Sensor"},
{"model":"lumi.remote.b286acn01","did":"lumi.158d0002b49c8a","name":"Switch"},{"model":"lumi.sensor_motion.aq2","did":"lumi.158d0002b7641a","name":"Aqara Motion Sensor"}]
Any ideas ?
