You do not need to configure this filter manually, the binding comes with pre-configured filters, also for Radius. If you remove the channel configuration, it should work. The start parameter is wrong since it will exclude records still valid, but starting before the beginning of current month. The pre-configured filter has 2023-01-01 as cutoff date.
You can also see this in the records you receive - they are only valid in the future:
I would need to understand your use-case to comment on that. What I can say is that having this amount of items is bad design and will not be implemented in the binding. Most likely this was “invented” to work around the lack of timestamped states. In 2025 we should start receiving spot prices in intervals of 15 minutes. Then what - 192 items that will be rotated every 15 minutes? I can’t even wrap my head around how to use that for calculations.
This pull request will probably pave some of the way:
I recently renamed all channels to prepare for supporting time series (e.g. from current-spot-price to just spot-price).
For now, instead of using the serialized JSON content, you could also simply use the thing action getPrices for retrieving all the prices in a rule. This will also perform much better.
Perhaps some of the thing actions could be helpful for some of your use-cases, for example if you need to calculate periods with lowest prices.
