Hi @Cato_Sognen Great binding. I have a small issue with my Velux rollershutters. Sending a command to them doesnt work, and i believe its because the pulse length is too short. When i use the remote, a simple press isnt enough, i need to hold it for a short time. Is there anyway to implement a way of telling it how long it should send the command with one press?
Edit: I just wanted to write how this binding was not working for no apparent reason. Then my OH server locked up and after a hard reboot everything started working, even Alexa worked. So thanks!
I believe @Cato_Sognen said they were in a consistent format to what you put in the transform.map file.
I wonder if there might be possibilities, to get the binding changed to read IR commands from files as per this mqtt control method. It would allow us to share remote code files more readily.
And by installing this script, it allows for easy recording that’s not android based. I recorded a bunch of remote commands from various remotes and have been adding them to eschava’s gitbhub (and my own version of the same script).
Hello, I am new to this binding, I found IV and key on some github page, and copied and pasted it blindly with more than 40 characters including spaces and commas. I saw on other post of yours it only contain 32 characters. Do we have to remove the first 2 characters and commas and spaces?
I tried both (with and without commas, spaces, and '0x’s) but paper UI shows that it is initializing for minutes already. Can you help me point what did I do wrong?
hello again, I successfully install broadlink binding, but no action is happened, except RM2 temperature is now detected from paper UI. here is my item on items.items (is the mac address case sensitive?)
and here is my code extracted from RM bridge that I used before using broadlink binding, using http request
[{“data”:“b20734003110112f310f112e112e112f3110112f112f310f112f310f310f310f310f310f112f112f3110310f112e112f3110112e110001e200000000”,“mac”:“b4:43:0d:c3:0f:f5”,“name”:“front hall on”},
{“data”:“b20b34002f1110303011103110301030301110301030301110312f112f112f113011301110301030301130112f11103010301030100001e400000000”,“mac”:“b4:43:0d:c3:0f:f5”,“name”:“front hall off”}]
here is the events.log
2017-09-01 11:03:06.830 [ItemCommandEvent ] - Item ‘Light_FF_Front’ received command Front_Light_OFF
2017-09-01 11:03:06.860 [ItemStateChangedEvent ] - Light_FF_Front changed from Front_Light_ON to Front_Light_OFF
Nothing hapened. Do anybody see what is wrong here?
EDIT: I even tried to put the ‘data’ string directly to sendCommand(Light_FF_Front, ‘data’) and nothing happened
On my remote, the signal to turn on and to turn off is the same.
It means that remotely I send always the same command without knowing the current state.
I do think that the persistency could help me but In this case that the AC should be controlled only from openhab and I should not use anymore original remote.
Am I right?
Is there a better way?
* 2 one ways together on a same light
i know that the TC are one ways. i mean that if i turn off the first one, the second one will be still on.
is it possible to make a rule to synchronize them?
SmartOne Alarm & Security Kit Smart Home Automation
i have added succesfully
Broadlink RM Pro -RM2 [10.100.102.101]
Broadlink RM Mini -RM3 [10.100.102.102]
BroadLink SP3 Home Socket -SP2 [10.100.102.103]
below the openhab.log 2017-09-01 11:15:48.461 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘broadlink:rm2:34-ea-34-c7-c9-15’ to inbox. 2017-09-01 11:15:48.470 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘broadlink:rm3:34-ea-34-c7-76-86’ to inbox. 2017-09-01 11:15:48.487 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘broadlink:s1c:b4-43-0d-fe-e1-bf’ to inbox. 2017-09-01 11:15:48.495 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘broadlink:sp2:34-ea-34-f5-ae-aa’ to inbox. 2017-09-01 11:15:48.504 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘broadlink:sp2:b4-43-0d-ee-d6-04’ to inbox. 2017-09-01 11:15:58.370 [INFO ] [link.internal.socket.BroadlinkSocket] - Socket closed 2017-09-01 11:15:58.375 [INFO ] [link.internal.socket.BroadlinkSocket] - Receiver thread ended 2017-09-01 11:19:39.350 [ERROR] [home.core.thing.binding.ThingFactory] - Thing factory (class org.openhab.binding.broadlink.internal.BroadlinkHandlerFactory) returned null on create thing when it reports to support the thing type (broadlink:s1c). 2017-09-01 11:19:39.352 [WARN ] [g.discovery.internal.PersistentInbox] - Cannot create thing. No binding found that supports creating a thing of type broadlink:s1c.
and below the event log
2017-09-01 11:14:21.441 [ItemChannelLinkAddedEvent ] - Link ‘AC_LIVINGROOM-broadlink:rm2:34-ea-34-c7-c9-15:command’ has been added. 2017-09-01 11:14:21.453 [ItemChannelLinkAddedEvent ] - Link ‘WALL_LIVINGROOM-broadlink:rm2:34-ea-34-c7-c9-15:command’ has been added. 2017-09-01 11:14:21.455 [ItemChannelLinkAddedEvent ] - Link ‘Temperature-broadlink:rm2:34-ea-34-c7-c9-15:temperature’ has been added. 2017-09-01 11:14:21.457 [ItemChannelLinkAddedEvent ] - Link ‘AC_ROOM-broadlink:rm3:34-ea-34-c7-76-86:command’ has been added. 2017-09-01 11:14:28.709 [InboxAddedEvent ] - Discovery Result with UID ‘ntp:ntp:local’ has been added. 2017-09-01 11:15:48.463 [InboxAddedEvent ] - Discovery Result with UID ‘broadlink:rm2:34-ea-34-c7-c9-15’ has been added. 2017-09-01 11:15:48.476 [InboxAddedEvent ] - Discovery Result with UID ‘broadlink:rm3:34-ea-34-c7-76-86’ has been added. 2017-09-01 11:15:48.487 [InboxAddedEvent ] - Discovery Result with UID ‘broadlink:s1c:b4-43-0d-fe-e1-bf’ has been added. 2017-09-01 11:15:48.496 [InboxAddedEvent ] - Discovery Result with UID ‘broadlink:sp2:34-ea-34-f5-ae-aa’ has been added. 2017-09-01 11:15:48.505 [InboxAddedEvent ] - Discovery Result with UID ‘broadlink:sp2:b4-43-0d-ee-d6-04’ has been added. 2017-09-01 11:17:23.788 [InboxRemovedEvent ] - Discovery Result with UID ‘broadlink:rm2:34-ea-34-c7-c9-15’ has been removed. 2017-09-01 11:17:23.807 [ThingAddedEvent ] - Thing ‘broadlink:rm2:34-ea-34-c7-c9-15’ has been added. 2017-09-01 11:17:23.849 [hingStatusInfoChangedEvent] - ‘broadlink:rm2:34-ea-34-c7-c9-15’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING) 2017-09-01 11:18:01.307 [InboxRemovedEvent ] - Discovery Result with UID ‘broadlink:rm3:34-ea-34-c7-76-86’ has been removed. 2017-09-01 11:18:01.313 [ThingAddedEvent ] - Thing ‘broadlink:rm3:34-ea-34-c7-76-86’ has been added. 2017-09-01 11:18:01.349 [hingStatusInfoChangedEvent] - ‘broadlink:rm3:34-ea-34-c7-76-86’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING) 2017-09-01 11:18:22.361 [InboxRemovedEvent ] - Discovery Result with UID ‘broadlink:sp2:34-ea-34-f5-ae-aa’ has been removed. 2017-09-01 11:18:22.365 [ThingAddedEvent ] - Thing ‘broadlink:sp2:34-ea-34-f5-ae-aa’ has been added. 2017-09-01 11:18:22.394 [hingStatusInfoChangedEvent] - ‘broadlink:sp2:34-ea-34-f5-ae-aa’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING) 2017-09-01 11:19:06.372 [InboxRemovedEvent ] - Discovery Result with UID ‘broadlink:sp2:b4-43-0d-ee-d6-04’ has been removed. 2017-09-01 11:19:06.376 [ThingAddedEvent ] - Thing ‘broadlink:sp2:b4-43-0d-ee-d6-04’ has been added. 2017-09-01 11:19:06.405 [hingStatusInfoChangedEvent] - ‘broadlink:sp2:b4-43-0d-ee-d6-04’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
I would use switchable in stead of lighting, because its only on and off you need, but i don’t think it will work either cause the string calls the .map file which can contain a lot off broadlink commands.
Something that should work is an http command, u can make those with rm bridge and with the rm plugin android app
I use that to control my chinese robot vacuum cleaner, works well with a dedicated mini!
The plugin cato is building is still a beta so not everything is working or clear yet…
rule "aircon simple on"
Item Klima_Dummy received command ON
Airco_Remote.sendCommand("AIRCO_AUTO_26")
rule "aircon quiet on"
Item Klima_Quiet_Dummy received command ON
Airco_Remote.sendCommand("AIRCO_SILENT_26")
rule "aircon Dehumid on"
Item Klima_Dehumidify_Dummy received command ON
Airco_Remote.sendCommand("AIRCO_DEHUMIDIFY")
rule "aircon Realfeel on"
Item Klima_Realfeel_Dummy received command ON
Airco_Remote.sendCommand("AIRCO_REALFEEL")
rule "aircon off"
Item Klima_Dummy received command OFF or
Item Klima_Realfeel_Dummy received command OFF or
Item Klima_Dehumidify_Dummy received command OFF or
Item Klima_Quiet_Dummy received command OFF
Airco_Remote.sendCommand("AIRCO_OFF")
In a later iteration, I’ll add logic to select the temp according to room temp (from my heating system).
Hello nakh, I’m not expert in this binding too, but I quite understand on how broadlink in general works.
Air conditioner
In order to know the current state, you’d better off installing current meter on your aircon, so if current is 0 then Aircon status is off, and if current is > 1 (or whatever low value you choose) then aircon status is on. Current is different on each aircon standby state, so you should experiment yourself.
2 one ways
I don’t understand on this question, but since broadlink switch only have 1 way communication, we can only send command the switches. If it means that we have no way to tell if the lamp is on or off without power current meter.
SmartOne Alarm
I don’t have any of these, so I cannot help
Weirdly Chosen,
X-ray helped me so much it mine turn to return the favor. GitHub is not the correct page for the Authentication Key and IV parameter. When you look at the status of your IR blaster in things what does it show as the status? If it doesn’t says online then the configuration is not correct. I hate to be cryptic with my answer but this site can’t reference that page directly or this post would be deleted. You need to do more research to get the correct Authentication Key and IV parameter for the bindings.
Once you find the right page
Look for these key words.
Authentication key = initial key
IV parameter = Initial vector
thank you for your help, Eric. My IR blaster is online, but nothing happened. I tried both IR and RF command. No IR blasted from RM devices. Viewed using phone’s camera.
EDIT: I deleted the comma, space, and '0x’s from github’s page to achieve 32 character initial key and IV, if it may help.
