Hi
Is their a list what Thermostad is working ?
devices with Tuya should be able to be flashed with other firmware. See:
Mikes Thermostat
Joerg
Hello Florian,
could you please add the ability od ADJ settings change, please?
Im unable to get it works :-(.
Thank you very much
J.
Hi all, first of all, thanks a lot to @flo-02-mu Florian for developing this addon.
I have following this post time ago, but not until now I have decided to use it. I have some questions, that would be happy to know before use the addon. I will use it with a Beok thremostat. I donāt know yet if it works, but I hope that yes!
The questions are:
- I have found several binding versions, I supose that the last one (0.1.10) are the correct to use more debbuged one. The one that is on the first post is 0.1.7.
- Is the binding able to send commands to the thermostat? Or only to read temp, state, etc? I would to do the automation of switch on/off based on OpenHAB, so I need to send commands to it.
- And the last one: There is some documentation to create things and items? I will use the discovery to recover the parameters of thermostat (I know the IP, but not key, etc), but once done it, I will prefer to make the things and items manually.
Thanks a lot in advance.
Ruben
Well, I have tested it⦠and all works perfectly. I have installed last version found on thread (0.1.10), auto discovered the thermostat at first attempt watching the log. I have created manually a .items (not things, I used the things created by autodiscover).
My only doubt⦠can I switch on or off the thermostat from the OH? Or is a āread onlyā addon?
Thanks a lot in advance!
Ruben
Well⦠it seems to actuate to Beok Thermostat⦠but not sure⦠or some strange interaction with Beok App. Also donāt understand very well about āautoā / āmanualā mode, because I have actually in āautoā mode, but message from Beok inform that is on āmanualā, but changing it, seems to change on thermostatā¦
Edited:
Very good, it is working also to send comands to the thermostats.
Thanks again to @flo-02-mu Florian. I think that this binding must be on OpenHAB official bindings.
Ruben
@flo-02-mu Iām using your binding a few weeks now and itās working really great.
Will you port this binding to the upcoming openhab 3 release?
If somehow possible, yes. As I am using 4 of these devices on my own, I have a high interest in upgrading as well. The issue is: The work relies on a 3rd party library (GitHub - mob41/broadlink-java-api: A clean Broadlink API for Java) that is not yet java 11 compatible. There are PRs out though. If there is no movement, I might need to for the lib and bundle it directly. The issue with the library is also that it is reverse engineered and thatās why it is probably hard to include it into OH directly.
I was also thinking about integrating it into the other broadlink binding, but that one has a totally different focus. So maybe Iāll rename mine to just narrow it down to the thermostats. Letās see. Somehow this binding will continue.
Thatās good news. Sounds like a lot of work though. Thanks for the effort that are putting in that binding!
Shouldnt be OH3 compatible to all OH2 bindings? So it might work or not?
But a āstand aloneā binding would be great to. Maybe u can intigrate it offical to OH
I finally took the action to create a PR: https://github.com/openhab/openhab-addons/pull/9260
Build that is supposed to work with Openhab 3.0 is available for download at https://github.com/flo-02-mu/openhab2-addons/releases/tag/0.2.0
I might pick up feature work again if the binding got integrated into openhab.
hi =)
can u take a look at this. sometimes it comes every few minutes. sometime hours without ?!
2021-01-09 00:31:01.053 [ERROR] [al.handler.FloureonThermostatHandler] - Error while retrieving data for broadlinkthermostat:floureonthermostat:34021da816
java.lang.ArrayIndexOutOfBoundsException: Index 34 out of bounds for length 0
at com.github.mob41.blapi.pkt.cmd.hysen.BaseHysenCommand.execute(BaseHysenCommand.java:38) ~[bundleFile:?]
at com.github.mob41.blapi.dev.hysen.BaseHysenDevice.getAdvancedStatus(BaseHysenDevice.java:102) ~[bundleFile:?]
at org.openhab.binding.broadlinkthermostat.internal.handler.FloureonThermostatHandler.refreshData(FloureonThermostatHandler.java:192) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
FYI, the PR for the binding has been merged, so with release 3.1 it will officially be part of openhab. And thanks to the code review there are some improvements under the hood.
Congratulations!!!
You found some solution
Hello Florian,
the temperature offset ātemperature offsetā is not changing the value.
After refreshing data from thermostat, the value is changed back.
Is it possible to fix it please? Iām novic in Java, and i canāt to fix it :-(.
Thank you very much,
Juraj
Hey,
is there solution for the COMMUNICATION_ERROR
āError while retrieving data for broadlinkthermostat:floureonthermostat:Temp: Index 34 out of bounds for length 0ā?
Christoph
Unfortunatly i was upgrading from OH3.3 to 4.0 before i used the binding from there: https://community.openhab.org/t/broadlink-binding-for-rmx-a1-spx-and-mp-any-interest/22768/1557
unfortunatly at the moment OH is unable to find my rm3mini [FW v44057] device via scanning. Adding manually will show it online but activating learning mode does not work.
extract openhab.log:
2023-08-06 08:39:17.951 [WARN ] [com.github.mob41.blapi.BLDevice ] - RM2 enter learning received error: fffffffb / -5
extract openhab.events.log
2023-08-06 08:39:17.910 [INFO ] [openhab.event.ItemCommandEvent ] - Item āRm_Universal_Device_Learning_Modeā received command ON
2023-08-06 08:39:17.911 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item āRm_Universal_Device_Learning_Modeā predicted to become ON
2023-08-06 08:39:17.911 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:17.911 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item āRm_Universal_Device_Learning_Modeā changed from OFF to ON
2023-08-06 08:39:17.914 [INFO ] [openhab.event.ItemCommandEvent ] - Item āRm_Universal_Device_Learning_Modeā received command ON
2023-08-06 08:39:17.915 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item āRm_Universal_Device_Learning_Modeā predicted to become ON
2023-08-06 08:39:17.915 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:17.918 [INFO ] [openhab.event.ItemCommandEvent ] - Item āRm_Universal_Device_Learning_Modeā received command ON
2023-08-06 08:39:17.918 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item āRm_Universal_Device_Learning_Modeā predicted to become ON
2023-08-06 08:39:17.918 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:17.920 [INFO ] [openhab.event.ItemCommandEvent ] - Item āRm_Universal_Device_Learning_Modeā received command ON
2023-08-06 08:39:17.921 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item āRm_Universal_Device_Learning_Modeā predicted to become ON
2023-08-06 08:39:17.921 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:17.952 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:17.968 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:17.986 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:18.004 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:19.354 [INFO ] [openhab.event.ItemCommandEvent ] - Item āRm_Universal_Device_Learning_Modeā received command OFF
2023-08-06 08:39:19.354 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item āRm_Universal_Device_Learning_Modeā predicted to become OFF
2023-08-06 08:39:19.355 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to OFF
2023-08-06 08:39:19.355 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item āRm_Universal_Device_Learning_Modeā changed from ON to OFF
2023-08-06 08:39:24.494 [INFO ] [openhab.event.ItemCommandEvent ] - Item āRm_Universal_Device_Learning_Modeā received command ON
2023-08-06 08:39:24.495 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item āRm_Universal_Device_Learning_Modeā predicted to become ON
2023-08-06 08:39:24.496 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
2023-08-06 08:39:24.496 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item āRm_Universal_Device_Learning_Modeā changed from OFF to ON
2023-08-06 08:39:24.513 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item āRm_Universal_Device_Learning_Modeā updated to ON
Any Idea how to tell the Binding using coirrect version of device?
