2025-01-13 09:54:00.642 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘broadlinkthermostat:floureonthermostat:e6819dd6a2’ changed from OFFLINE (COMMUNICATION_ERROR): Error while retrieving data for broadlinkthermostat:floureonthermostat:e6819dd6a2: Index 39 out of bounds for length 30 to ONLINE
2025-01-13 09:54:11.524 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘broadlinkthermostat:floureonthermostat:e6819dd6a2’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Error while retrieving data for broadlinkthermostat:floureonthermostat:e6819dd6a2: Index 39 out of bounds for length 30
Did anyone have this problem?
I use the latest openHAB 4.3.1 - Broadlink Thermostat Binding 4.3.1
it had problems in the older versions aswell… as soon as i DISABLED/ENABLED the thing it worked for some while…
a workaround is having a script check the thing status every 5 minutes and then disable/enable by JS Script. but that is not clean
Anyone?
Petar
