Using Openhabian with Openhab 2.5.0 #1562 with Mosquittto installed
Receiving a ton of these messages in the logs:
FrameworkEvent ERROR - org.openhab.binding.mqtt.generic
Caused by: java.lang.NoClassDefFoundError: org/openhab/binding/mqtt/TransformationServiceProvider
Caused by: java.lang.ClassNotFoundException: org.openhab.binding.mqtt.TransformationServiceProvider cannot be found by org.openhab.binding.mqtt.generic_2.5.0.201903282223
I was copying and pasting from github to a new things file to be lazy instead of adding generic MQTT things through PaperUI like all of my other MQTT2 things are configured. Once I saved the .things file I noticed a new MQTT system broker and all of my MQTT2 things broke. MQTT1 items are still working fine. I removed the new MQTT broker, added a new one through the MQTT service, and have switched a couple of things to the new one, switched them back to the old one that is online, uninstalled and reinstalled the MQTT2 binding but my generic MQTT things are still Uninitialized. I’ve been searching through forums yesterday evening and this morning and reading as much as I can about the MQTT2 binding, but I have not been able to figure out how to undo my breaking config.
I am 95% certain this is the culprit that installed the new broker when my MQTT2 things broke:
miflora.things excerpt
Bridge mqtt:systemBroker:MqttBroker "MQTT Broker" [ brokerid="embedded-mqtt-broker" ]
I’ve since deleted the .things file and removed the new thing for the systemBroker, but I assume it installed the new embedded broker or something else conflicting with my mqtt2 broker.
