Hi, today I broke my openhab instalation. I was trying to resolver a zigbee problem, i touch some thing a now nothing works. I have no logs only and empty frontail works.
I have openhab 3.0.1 runing in and openhabian instalation in a raspberry 3b+ in a hard drive.
The thing I know is what I do:
sudo openhab-cli reset-ownership
sudo openhab-cli stop
sudo openhab-cli clean-cache //ask me to stop the service
sudo systemctl stop openhab.service
sudo systemctl start openhab.service
From here nothing works.
At some point sytemctl warms me:
arning: The unit file, source configuration file or drop-ins of openhab.service changed on disk. Run 'systemctl daemon-reload' to reload units.
sudo systemctl daemon-reload
I can accese the openhab-cli, openhabian-config, i can see frontail. But nothing happend.
Also in:
sudo systemctl status openhab.service
● openhab.service - openHAB instance, reachable at http://openhab:8080
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: active (running) since Mon 2021-04-05 11:43:21 -03; 3s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 3444 (java)
Tasks: 10 (limit: 2181)
CGroup: /system.slice/openhab.service
└─3444 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/openhab -Dopenhab.logdir=
Apr 05 11:43:21 openhab systemd[1]: Started openHAB instance, reachable at http://openhab:8080.
But again nothing happend.
