Brother DCP-J525W Ink Level
Hi, I want to show ink level of BROTHER DCP-J525W with snmp, and I can’t get it to work, when i was using home asisstant, there was a brother printer plugin which showed left ink in percentage and it was using snmp, is there any way to make it work on openHAB?
Have you seen the generic snmp binding?
The issue with SNMP and Brother is, it does not provide the levels of the toner. It only says that it is almost empty or almost full… :pensive:
I did integrate the ink level through the HTTP Binding and some Regex Transformation (XPath was not an option as of the namespace handling).
See Brother printers - REGEX/XSLT help requested - #5 by ronnypolley
