Hi Ivan (@zar1978)
your last formatted log does not show any message related to the IR sensor with WHERE=312, so is useless.
The only strange things I also noticed in your .items configuration you have:
Switch sensore_IR_INGRESSO "Living Room IR sensor" <motion> { channel="openwebnet:bus_dry_contact_ir:7f095c6d:sensor" }
while the correct format should include the device where, like this:
Switch sensore_IR_INGRESSO "Living Room IR sensor" <motion> { channel="openwebnet:bus_dry_contact_ir:7f095c6d:312:sensor" }
note I added 312: before sensor.
Also you have to make sure the right Bridge ID is specified, it looks strange that for switch & rollershutter items you have 89f9d7f7 and then for the IR sensor you have 7f095c6d: this does not look correct at all.
So in the end to create items manually i suggest you go first to your PaperUI > Config > Things then click on your IR thing you should have added/configured by PaperUI and you will see info like this:
Hi Massimo, Thanks for the reply. I tried to make the suggested changes without getting results. I also tried to delete the item and create it from the PaperUI. This is the result:
I add that ITEM must add it manually and that the address of the BRIDGE ID is inserted automatically and does not correspond with the BRIDGE ID entered for the remaining automation
Maybe something is broken/ wrong in you configuration, you said you have touched the JSONDb and that is a very delicate steps that can destroy the configuration(not a good suggestion at all).
I suggest you start from zero: remove all thing and items (both added from text files, manually and with auto discovery)
Then add the gateway manully, then add the Contact IR sensor by discovery.
If ithe IR sensor does not get discovered something is already wrong.
But you can try to add it manually but You have to select form the menu the bridge you just created.
Bye
M
Ivan last test you can do is to use the official opwenwenet client from BTicino (search other threads in this forum for info and dowload link) , connect to your gateway, activate event mode on the client and then pass in front of your sensor and see if any event message is sent on the bus when you pass in front of it.
If no message in sent , then no, you cannot integrate this device with OH and the OpenWebNet Binding.
