Is there a binding for Bticino in OpenHab2?
May I use an old binding for OpenHab1?
Best regards.
Best regards.
I got pointed to this link by John Cocula
https://openhab.ci.cloudbees.com/job/openHAB1-Addons/lastSuccessfulBuild/artifact/bundles/binding/org.openhab.binding.bticino/target/
I have not managed to get it working tho. It dumps a whole lotta errors.
Make sure you have uninstalled the old JAR file. Removing it from addons
is not enough under openHAB 2. At the openhab>
prompt, do bundle:list
to find the possibly old bundle and bundle:uninstall
it. Provide logs if you are sure it is the 1.9.0-SNAPSHOT version only running. You can gather potentially useful logs if you issue log:set TRACE org.openhab.binding.bticino
at the openhab>
prompt.
Hi John… It worked… Ver 1.8.3 was srill loaded… Tx for helping… I appreciate
Kind regards
Based on your report that the binding works under openHAB 2:
In OH2 I have added Bticino binding.
Best regards.
1.9 bindings must be configured in .items files. See https://github.com/openhab/openhab/wiki.
I followed your instructions and so I have BTcino installed.
When insert bundle:list command
But it is not appeared on the paper UI
Could you help me to figure out what is wrong here?
same problem here…can anyone help?
