Good moorning m4rk, i dont know whats was going on, for sure there was something that stuck the communication between Alexa command and scenario. Everything was right as soon i cleanup cache, tmp file and refreshed items and things files.
Now, with a nice routine, i can verbally open the gate!
Hi @Omar_Tiziani, its pretty easy. In the MH202 menu, in the objets list, you will find the family “Videophone” and as a subkeys “lock”. Than if you use the “lock” and you set the address to P =0 , than the MH202 send the string
*8*19*20## and *8*20*20##
and the gate opens bypassing the binding restrictons.
Hi Mark,
I state that I don’t know Linux,
I’m passing openhab on rapi3b …
I regularly installed the version of openhabian with etcher whale, configured paperUi and copied the file kindly managed by jebu in the share \ openhab2-addons folder, but I can’t find anything, no Bus, no things …
Do I need to activate dependencies?
if yes, how do i access the karaf console?
If yes, the syntax is the same as openhab 2.5? … “feature: install openhab-transport-serial”
and “feature: install openhab-core-io-transport-upnp”
Yes. The instructions are in the install instructions at the top of thread. The bit about dependencies links to instructions how to open the karaf console.
I’m still here to disturb you …
I managed to access the karaf console with putty from win10, but when I activate the dependencies it gives me this message:
-bash: feature: install: command not found … what am i doing wrong?
Thanks again
Marco
Hi Mark
I wanted to thank you infinitely for your patience … I’m really a donkey with Linux, but I managed to solve thanks to your precious help. Now I have all my system running inside a little box of raspberries and I have eliminated the clutter of the desktop PC …
Good morning everyone,
I hope someone can help me about connection error to the bridge,
Two days ago I have create e backup of my raspberry (only create backup not restore) after openhab lost connection whit the F454. After I have tried to fix he issue following theese steps :
Manualy updating the binding version to the last one (once I have solved in that way);
cleaning tmp files and cache :
sudo systemctl stop openhab2.sevice
sudo openhab-cli clean-cache
sudo systemctl start openhab2.sevice.
for shure I have reinstalled the dipendance.
Unfortunaly the bridge is no connettected and if I try to add a new thing openhab does’nt find anything.
for me could be good also create the bridge manualy, using a file “.things” for ex , and link it to the things the I already have configurated in my home.
Unfortunaly I’m not expert so I dont know how I can do.
hello All,
I’m new here I’m just starting, in my home a have myhome bticino with:
F454
Lights
roll-up shutter
Alarm
Energy mng
I would like to integrate it with Openhab
I installed it in my raspy … I have right now one question about the fix, can some of you specify the path where I need to paste the .jar file to hack the binding expiry?
hi claudio,
i think it depends what system you use and how much is installed there.
for example i use a raspi 4b with 4gb ram and have only openhab with bticino, 1wire, mqtt working. my system takes about 15 minutes until all is up
