Binding stopped working. I read that the time has expired.
I use the version of M4, in which massi I fixed the usb stick error and sent it to me for a test. Installing a patched M3 does not suit me because of this error.
I turned off the Internet connection for raspberry on the router (so that the time was not set automatically), changed the time to January 1, 2020. Binding start work. The solution is not the best, but working.
Thing bus_cen_scenario_control Abilita_A51_Gen_A_C_Auto "CEN Abilita Gen. A.C. Auto" @ "CEN" [ where="015", buttons="2" ] //CEN abilitazione A51 - Gen. A.C. Auto
cen items
String iAbilita_A51_Gen_A_C_Auto "CEN Abilita Gen. A.C. Auto" <network> (gSystem) {channel="openwebnet:bus_cen_scenario_control:myGateway:Abilita_A51_Gen_A_C_Auto:button_2"}
but when i try to push any buttoms (pressed, eccecce) in the paper UI , the log stated:
17:58:46.638 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'iAbilita_A51_Gen_A_C_Auto' received command PRESSED
17:58:46.640 [INFO ] [arthome.event.ItemStatePredictedEvent] - iAbilita_A51_Gen_A_C_Auto predicted to become PRESSED
but no command is sent to the bus. Infact with the openwebnet sniffer i cant see the relevant command.
i think this is your problem. i suggest you want to use cen with a=0 and pl=15? if one part has two digits then the other must be two digits, too. to be honest i never tried an a=0 but try if it works. so your command has to be:
where="0015"
maybe you have to reboot, i had several times problems when i edited a thing, but after reboot it always worked for me
not quite as easy i think. when running the backup that i do i have to enter sudo-password. i read that it is possible but really not recommended to make this work without the need of a password. but sorry i don´t know enough about it to be able to tell you more.
i run the backup manually - always when i edited my files or before i run updates. this is enough and saves filespace on my backup-nas
Thanks a lot for your suggestion!
Anyway i believe the problem is deeper. Think that the Cen+ works perfectly , the problem is only related to the CEN. I decided to try using the paper UI instead of the Things and Items file and i made a CEN thinks using the openwebnet manual function and than the automatic item file. Regardless of the setting i use as button A or PL, the command is always
*2*1*0311##
My bindings is the one modified with a longer expiration date that i manually installed. Everythings works well except for this CEN command.
Because i believe you are using the same bindings, Would you be so kind to make a test on your machine to understand if problem is tight to binding or my installation?
hi @Costa
i like to try to help you, but i don´t quite understand what i can test for you. first of all: yes, i use the binding with the modified expire-date. and i also use cen and cen+ commands - but i use the file-based setting, not via paperui. so i can confirm that cen and cen+ is working, not good because only the “start-press” and the “extended-press” can be handled by the binding and mostly every change of cen-settings needs to restart openhab (or at least you have to change the name of the item)
*2*1*0311##
this command that you ask is for opening shutter with a=03 pl=11
*2*1*0311##```
is the command sent by the cen when i push the PRESSED_EXT button even if the PL is 12 !! Thats the reason it drive me nuts!
I will make some test to understand what going on.....
Costa
but this command (21*0311##) is definetly a automation-command for opening a rollershutter. perhaps you use a mh202 or a f454 or something like that? you might have a scenario in one of these components that opens that shutter when this cen-command is sent? or you have a rule in openhab that causes this?
Info/idea for binding users…If you are using Grafana charts then a useful feature is to be able to add via Rules annotations to the charts on a dashboard. eg Here I got my blind CEN activated scenarios to be added to the room temperature charts…
It works for me as well. I ran into the binding expiration problem just I few days ago after a disconnection. Many thanks Jebu, you saved me. Just in case, could you post a step by step guide to apply this fix in the future if needed?
I have switches responding to long and short presses with different actions. Please post on the above thread and I will respond there. I think I see reason for your problem.
Hi everyone! I recently started with openhub, I installed it on raspberry pi 4 (raspabian) to manage my btcino myhome system with gateway f454.
The lights works fine and also the blinds with paperui (I have an items file). But with Amazon Alexa the blinds go up if I say “Alexa close the blind”, and they go down if I ask Alexa to open them! Why? What am I doing wrong?
I don’t have any log error…
Thank you.
Hi, i’m having some problem whit thermoregulation.
It seem is not possible to switch the mode of the zone to auto or manual. Off and antifreeze works correctly. Somebody expierenced and maybe fixed the problem? I’ve a 99 zone system with 3550 unit.
Thanks in advanced
hi filippo,
i have the same equipment - and the same issues. this is a long known bug in the binding and never fixed. long time ago i was allowed to test a beta where this bug was eliminated, but the developer never implemented it
It’s a pity…Probably also easy to fix, just message adjusting…thank you for your answer! Hope one day will work! Someone knows if it’s possible to have the source file in order to try fix small problems like this?
