Hopefully its a bug, certainly a restart of the binding fixes my issue. There is one node, Node 4: which is a Fibaro Dimmer that on occasion, randomly and unable to be reproduced just refuses to turn off.
I have debug running constantly and looking at the logs its just FULL of Node 4 traffic. The only way to fix this was to restart the bundle.
I tried a heal, reinitalise, remove the channels and relink them. All to no avail.
You might want to tag this post with the zwave tag.
Yeah, I see node 4 is reporting its status continuously (at least once a second, if not more) without being polled. That suggests to me that the device is in a weird state, and may also explain why it’s not responding to commands.
Can you identify the point in the log when the device starts to show this behavior? That may help explain why it’s acting that way.
Dont think so Ben, you mention latency, mines right next to the controller in this instance and not latency related.Mine works for days, then suddenly has a fit. Only fix, restart of the binding.
Perhaps there can be some mechanism inside the software that if this occurs it restarts itself?
