I’m using the rest-api reading a sitemap and found a strange behavior:
Item:
String UG_Waschmaschine_Status "Waschmaschine Status [MAP(Washer.map):%s]" <washingmachine>
In Sitemap:
Default label="Wasch-maschine[MAP(OHEZ_Washer.map):%s]" item=UG_Waschmaschine_Status
Result in API:
"widgetId": "0501",
"type": "Text",
"visibility": true,
"label": "Wasch-maschine[Auswaschen]",
"icon": "washingmachine",
"mappings": [],
"item": {
"link": "http://10.10.10.201:8080/rest/items/UG_Waschmaschine_Status",
"state": "3",
"transformedState": "3-Auswaschen",
"stateDescription": {
"pattern": "MAP(Washer.map):%s",
"readOnly": false,
"options": []
"type": "String",
"name": "UG_Waschmaschine_Status",
"label": "Waschmaschine Status",
"category": "washingmachine",
"tags": []
As seen, the transformedState don’t priorize the sitemap transforming, only showing the transformation defined in the item.
Shouldn’t a label with transformation in sitemap be higher priorized?
"label": "Wasch-maschine[Auswaschen]", << COMING FROM SITEMAP [MAP(OHEZ_Washer.map):%s]
"transformedState": "3-Auswaschen", << COMING FROM ITEM [MAP(Washer.map):%s]
"pattern": "MAP(Washer.map):%s", << COMING FROM ITEM [MAP(Washer.map):%s]
(OHZE_Washer transforming without Number before, correct in label, but not in transformed state)
Or do I think false?
