i think there is a little bug in the senseBox-binding.
I have in my sensebox an additional soil-temperature and soil-moisture-sensor.
The sensebox-Binding reads this temp. and moist. value instead of the air-temperature and air-moisture-values.
At the moment there is no configuration-option to bind the channel to a fixed sensor-id.
Here is an json-example of my sensebox.
Best Regards
Mirko
"title": "Temperatur",
"unit": "°C",
"sensorType": "HDC1080",
"icon": "osem-thermometer",
"_id": "6005d07cca495d001be58efc",
"lastMeasurement": {
"value": "5.15",
"createdAt": "2021-02-22T22:04:54.193Z"
"title": "rel. Luftfeuchte",
"unit": "%",
"icon": "osem-humidity",
"_id": "6005d07cca495d001be58efb",
"value": "84.84",
"title": "Luftdruck",
"unit": "hPa",
"sensorType": "BMP280",
"icon": "osem-barometer",
"_id": "6005d07cca495d001be58efa",
"value": "1010.80",
"title": "Beleuchtungsstärke",
"unit": "lx",
"sensorType": "TSL45315",
"icon": "osem-brightness",
"_id": "6005d07cca495d001be58ef9",
"value": "3072.00",
"title": "UV-Intensität",
"unit": "μW/cm²",
"sensorType": "VEML6070",
"_id": "6005d07cca495d001be58ef8",
"value": "0.00",
"title": "PM10",
"unit": "µg/m³",
"sensorType": "SDS 011",
"icon": "osem-cloud",
"_id": "6005d07cca495d001be58ef7",
"value": "20.70",
"title": "PM2.5",
"unit": "µg/m³",
"_id": "6005d07cca495d001be58ef6",
"value": "19.00",
"_id": "6005d07cca495d001be58ef5",
"title": "Bodenfeuchte",
"unit": "%",
"sensorType": "SMT50",
"value": "38.35",
"title": "Bodentemperatur",
"unit": "°C",
"_id": "6005d07cca495d001be58ef4",
"value": "3.50",
"_id": "6005d07cca495d001be58ef3",
"title": "Lautstärke",
"unit": "dB (A)",
"sensorType": "SOUNDLEVELMETER",
"icon": "osem-volume-up",
"value": "35.77",
"_id": "6005d07cca495d001be58ef2",
"title": "Windgeschwindigkeit",
"unit": "km/h",
"sensorType": "WINDSPEED",
"icon": "osem-particulate-matter",
"value": "12.48",
"_id": "6005d388ca495d001be70075",
"title": "WiFi RSSI",
"unit": "dBm",
"sensorType": "WIFI",
"icon": "osem-wifi",
"value": "-44.00",
"_id": "6005d43bca495d001be756cc",
"icon": "osem-sprinkles",
"sensorType": "RAIN",
"unit": "mm",
"title": "Rain / Transmit"
