Does anyone have a similar observation - or any known issue in b108x.
Tonight for the first time no more zwave reaction at all, realized in the morning - GUI still available but no reaction at all…seems not only zwave specific.
Log shows the following, which is an evidence that really nothing worked during the night:
2017-11-26 01:27:01.742 [vent.ItemStateChangedEvent] - HOhum changed from 60.10 to 60.30
2017-11-26 01:27:02.816 [vent.ItemStateChangedEvent] - HOrssi changed from -50 to -51
2017-11-26 01:27:03.953 [ome.event.ItemCommandEvent] - Item 'EtaKesselState' received command Bereit
2017-11-26 01:27:04.020 [ome.event.ItemCommandEvent] - Item 'AbgasTemp' received command 36
2017-11-26 01:27:04.058 [ome.event.ItemCommandEvent] - Item 'KesselRevSpeed' received command 0
2017-11-26 01:27:04.108 [ome.event.ItemCommandEvent] - Item 'KesselTemp' received command 56
2017-11-26 01:27:04.257 [ome.event.ItemCommandEvent] - Item 'PUtopTemp' received command 72
2017-11-26 01:27:04.300 [ome.event.ItemCommandEvent] - Item 'PUobenTemp' received command 69
2017-11-26 01:27:04.343 [ome.event.ItemCommandEvent] - Item 'PUmitteTemp' received command 67
2017-11-26 01:27:04.368 [ome.event.ItemCommandEvent] - Item 'PUuntenTemp' received command 43
2017-11-26 01:27:04.393 [ome.event.ItemCommandEvent] - Item 'EGthermo' received command 22.5
2017-11-26 01:27:04.424 [ome.event.ItemCommandEvent] - Item 'DGthermo' received command 16.5
2017-11-26 01:27:04.447 [ome.event.ItemCommandEvent] - Item 'HKegstate' received command Aus Heizgrenze Nacht
2017-11-26 01:27:04.501 [ome.event.ItemCommandEvent] - Item 'HKogstate' received command Aus Sommer
2017-11-26 01:27:04.522 [ome.event.ItemCommandEvent] - Item 'EGvlauf' received command 31
2017-11-26 01:27:04.546 [ome.event.ItemCommandEvent] - Item 'DGvlauf' received command 21
2017-11-26 01:27:06.465 [ome.event.ItemCommandEvent] - Item 'PowerTotal' received command 29.8
2017-11-26 01:27:06.475 [vent.ItemStateChangedEvent] - PowerTotal changed from 29.4 to 29.8
2017-11-26 08:29:14.611 [.ItemChannelLinkAddedEvent] - Link 'EntryEGMotionSensor_MotionAlarm-zwave:device:6f2c15ba:node2:alarm_motion' has been added.
2017-11-26 08:29:14.617 [.ItemChannelLinkAddedEvent] - Link 'WellWater_Power-zwave:device:6f2c15ba:node10:meter_watts' has been added.
2017-11-26 08:29:14.618 [.ItemChannelLinkAddedEvent] - Link 'PVng4_Switch-zwave:device:6f2c15ba:node42:switch_binary' has been added.
2017-11-26 08:29:14.620 [.ItemChannelLinkAddedEvent] - Link 'Devolo3_Switch-zwave:device:6f2c15ba:node43:switch_binary' has been added.
2017-11-26 08:29:14.622 [.ItemChannelLinkAddedEvent] - Link 'Devolo1_Switch-zwave:device:6f2c15ba:node44:switch_binary' has been added.
2017-11-26 08:29:14.624 [.ItemChannelLinkAddedEvent] - Link 'Router_Switch-zwave:device:6f2c15ba:node16:switch_binary' has been added.
2017-11-26 08:29:14.626 [.ItemChannelLinkAddedEvent] - Link 'HouseNr_Switch-zwave:device:6f2c15ba:node37:switch_binary' has been added.
2017-11-26 08:29:14.627 [.ItemChannelLinkAddedEvent] - Link 'LRMotionSensor_Temperature-zwave:device:6f2c15ba:node11:sensor_temperature' has been added.
and the openhab logs shows only a single message exactly at that point in time. so assumption that this is related. Thanks for checking!
2017-11-26 01:18:04.651 [WARN ] [.classic.internal.servlet.CmdServlet] - Received unknown command '---' for item 'RestO2state'
2017-11-26 01:21:04.284 [WARN ] [.classic.internal.servlet.CmdServlet] - Received unknown command '---' for item 'RestO2state'
2017-11-26 01:24:04.581 [WARN ] [.classic.internal.servlet.CmdServlet] - Received unknown command '---' for item 'RestO2state'
2017-11-26 01:27:04.171 [WARN ] [.classic.internal.servlet.CmdServlet] - Received unknown command '---' for item 'RestO2state'
2017-11-26 01:27:11.455 [WARN ] [org.apache.karaf.services.eventadmin] - EventAdmin: Blacklisting ServiceReference [{org.osgi.service.event.EventHandler, org.eclipse.smarthome.core.events.EventPublisher}={event.topics=smarthome, compone$
2017-11-26 01:30:04.911 [WARN ] [.classic.internal.servlet.CmdServlet] - Received unknown command '---' for item 'RestO2state'
2017-11-26 01:33:04.815 [WARN ] [.classic.internal.servlet.CmdServlet] - Received unknown command '---' for item 'RestO2state'
2017-11-26 01:36:04.197 [WARN ] [.classic.internal.servlet.CmdServlet] - Received unknown command '---' for item 'RestO2state'
