Build #1494 - NEST OFFLINE
From BUILD 1493 my nest thermostat has been OFFLINE
Intel platform - Ubuntu Server 18.04LTE - Apt package install
Java Zulu
openjdk version "1.8.0_181"
OpenJDK Runtime Environment (Zulu 8.31.0.1-linux64) (build 1.8.0_181-b02)
OpenJDK 64-Bit Server VM (Zulu 8.31.0.1-linux64) (build 25.181-b02, mixed mode)
2019-01-11 10:43:08.664 [ERROR] [ftware.os.linux.LinuxOperatingSystem] - Couldn't find any running processes, which is odd since we are in a running process. Process time values are in jiffies, not milliseconds.
2019-01-11 10:43:08.894 [ERROR] [ftware.os.linux.LinuxOperatingSystem] - Couldn't find any running processes, which is odd since we are in a running process. Process time values are in jiffies, not milliseconds.
2019-01-11 10:43:23.190 [hingStatusInfoChangedEvent] - 'nest:account:7cef08a0' changed from UNINITIALIZED to INITIALIZING
2019-01-11 10:43:23.290 [hingStatusInfoChangedEvent] - 'nest:account:7cef08a0' changed from INITIALIZING to UNKNOWN: Starting poll query
2019-01-11 10:43:23.292 [hingStatusInfoChangedEvent] - 'nest:structure:7cef08a0:NxiaUvbKLKt2NX6gsTigy_OsUdVfTl8bOKdE10NMPwDYX0z0xKzYdg' changed from UNINITIALIZED to INITIALIZING
2019-01-11 10:43:23.294 [hingStatusInfoChangedEvent] - 'nest:structure:7cef08a0:NxiaUvbKLKt2NX6gsTigy_OsUdVfTl8bOKdE10NMPwDYX0z0xKzYdg' changed from INITIALIZING to OFFLINE: Waiting for refresh
2019-01-11 10:43:23.182 [ERROR] [org.eclipse.smarthome.io.rest.sse   ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.sse
org.osgi.framework.BundleException: Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933) ~[?:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) ~[?:?]
	at org.eclipse.osgi.container.Module.doStart(Module.java:581) ~[?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:449) ~[?:?]
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:750) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:741) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:511) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:457) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:1001) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1382) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1)  [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://31.fwk1468303011/javax/ws/rs/ext/RuntimeDelegate.class to bundleresource://31.fwk1468303011/javax/ws/rs/ext/RuntimeDelegate.class
	at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:146) ~[?:?]
	at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:120) ~[?:?]
	at javax.ws.rs.core.MediaType.valueOf(MediaType.java:179) ~[?:?]
	at org.glassfish.jersey.media.sse.SseFeature.<clinit>(SseFeature.java:62) ~[?:?]
	at org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start(SseActivator.java:49) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772) ~[?:?]
	... 15 more
2019-01-11 10:43:23.326 [hingStatusInfoChangedEvent] - 'nest:thermostat:7cef08a0:dCd2AOytHIiKRTYPM00jxva1Q3Ryl-jm' changed from INITIALIZING to OFFLINE: Waiting for refresh
2019-01-11 10:43:23.327 [hingStatusInfoChangedEvent] - 'nest:thermostat:7cef08a0:dCd2AOytHIiKRTYPM00jxva1Q3Ryl-jm' changed from UNINITIALIZED to INITIALIZING
2019-01-11 10:43:27.203 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
	at javax.ws.rs.core.UriBuilder.newInstance(UriBuilder.java:95) ~[?:?]
	at javax.ws.rs.core.UriBuilder.fromUri(UriBuilder.java:119) ~[?:?]
	at org.glassfish.jersey.client.JerseyWebTarget.<init>(JerseyWebTarget.java:71) ~[?:?]
	at org.glassfish.jersey.client.JerseyClient.target(JerseyClient.java:290) ~[?:?]
	at org.glassfish.jersey.client.JerseyClient.target(JerseyClient.java:76) ~[?:?]
	at org.openhab.binding.nest.internal.rest.NestStreamingRestClient.createEventSource(NestStreamingRestClient.java:81) ~[?:?]
	at org.openhab.binding.nest.internal.rest.NestStreamingRestClient.reopenEventSource(NestStreamingRestClient.java:115) ~[?:?]
	at org.openhab.binding.nest.internal.rest.NestStreamingRestClient.start(NestStreamingRestClient.java:127) ~[?:?]
	at org.openhab.binding.nest.internal.handler.NestBridgeHandler.startStreamingUpdates(NestBridgeHandler.java:317) ~[?:?]
	at org.openhab.binding.nest.internal.handler.NestBridgeHandler.restartStreamingUpdates(NestBridgeHandler.java:300) ~[?:?]
	at org.openhab.binding.nest.internal.handler.NestBridgeHandler.lambda$1(NestBridgeHandler.java:111) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
@vzorglub
Did you read this? Perhaps it helps?
