My builds of the master locally (and on my own private buildserver) seem to be broken since yesterday or today, the last commit don’t look very suspicious, I get two different errors:
TeamCity buildserver :
[Step 1/3] [ERROR] Failed to execute goal org.openhab.tools:static-code-analysis:0.0.4:checkstyle (default) on project org.openhab.binding.airquality: Unable to execute mojo: An error has occurred in Checkstyle report generation. Failed during checkstyle execution: Failed to get overriding properties: Could not find resource '/opt/buildagent/work/5c3cd640ded15833/src/sat/binding.properties'. -> [Help 1]
[14:19:46][Step 1/3] [ERROR]
[14:19:46][Step 1/3] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[14:19:46][Step 1/3] [ERROR] Re-run Maven using the -X switch to enable full debug logging.
[14:19:46][Step 1/3] [ERROR] For more information about the errors and possible solutions, please read the following articles:
[14:19:46][Step 1/3] [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[14:19:46][Step 1/3] [ERROR] After correcting the problems, you can resume the build with the command
[14:19:46][Step 1/3] [ERROR] mvn <goals> -rf :org.openhab.binding.airquality
[14:19:46][Step 1/3] Process exited with code 1
With debug enabled:
[14:18:45][Step 2/5] [DEBUG] URLResourceLoader: Exception when looking for '/opt/buildagent/work/5c3cd640ded15833/addons/binding/org.openhab.binding.airquality/src/sat/binding.properties' at ''
[14:18:45][Step 2/5] java.net.MalformedURLException: no protocol: /opt/buildagent/work/5c3cd640ded15833/addons/binding/org.openhab.binding.airquality/src/sat/binding.properties
[14:18:45][Step 2/5] at java.net.URL.<init>(URL.java:593)
[14:18:45][Step 2/5] at java.net.URL.<init>(URL.java:490)
[14:18:45][Step 2/5] at java.net.URL.<init>(URL.java:439)
[14:18:45][Step 2/5] at org.codehaus.plexus.resource.loader.URLResourceLoader.getResource(URLResourceLoader.java:71)
[14:18:45][Step 2/5] at org.codehaus.plexus.resource.DefaultResourceManager.getResource(DefaultResourceManager.java:159)
[14:18:45][Step 2/5] at org.codehaus.plexus.resource.DefaultResourceManager.getResourceAsFile(DefaultResourceManager.java:91)
[14:18:45][Step 2/5] at org.apache.maven.plugin.checkstyle.exec.DefaultCheckstyleExecutor.getOverridingProperties(DefaultCheckstyleExecutor.java:518)
[14:18:45][Step 2/5] at org.apache.maven.plugin.checkstyle.exec.DefaultCheckstyleExecutor.getConfiguration(DefaultCheckstyleExecutor.java:379)
[14:18:45][Step 2/5] at org.apache.maven.plugin.checkstyle.exec.DefaultCheckstyleExecutor.executeCheckstyle(DefaultCheckstyleExecutor.java:217)
[14:18:45][Step 2/5] at org.apache.maven.plugin.checkstyle.AbstractCheckstyleReport.executeReport(AbstractCheckstyleReport.java:473)
[14:18:45][Step 2/5] at org.apache.maven.plugin.checkstyle.CheckstyleReport.executeReport(CheckstyleReport.java:154)
[14:18:45][Step 2/5] at org.apache.maven.reporting.AbstractMavenReport.generate(AbstractMavenReport.java:255)
[14:18:45][Step 2/5] at org.apache.maven.reporting.AbstractMavenReport.execute(AbstractMavenReport.java:143)
[14:18:45][Step 2/5] at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
[14:18:45][Step 2/5] at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojo(MojoExecutor.java:94)
[14:18:45][Step 2/5] at org.openhab.tools.analysis.tools.AbstractChecker.executeCheck(AbstractChecker.java:148)
[14:18:45][Step 2/5] at org.openhab.tools.analysis.tools.CheckstyleChecker.execute(CheckstyleChecker.java:121)
[14:18:45][Step 2/5] at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
[14:18:45][Step 2/5] at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
[14:18:45][Step 2/5] at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
[14:18:45][Step 2/5] at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
[14:18:45][Step 2/5] at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
[14:18:45][Step 2/5] at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
[14:18:45][Step 2/5] at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
[14:18:45][Step 2/5] at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
[14:18:45][Step 2/5] at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
[14:18:45][Step 2/5] at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
[14:18:45][Step 2/5] at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
[14:18:45][Step 2/5] at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
[14:18:45][Step 2/5] at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
[14:18:45][Step 2/5] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[14:18:45][Step 2/5] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[14:18:45][Step 2/5] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[14:18:45][Step 2/5] at java.lang.reflect.Method.invoke(Method.java:498)
[14:18:45][Step 2/5] at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
[14:18:45][Step 2/5] at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
[14:18:45][Step 2/5] at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
[14:18:45][Step 2/5] at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
[14:18:45][Step 2/5] at org.codehaus.plexus.resource.loader.URLResourceLoader.getResource(URLResourceLoader.java:123)
[14:18:45][Step 2/5] [DEBUG] The resource '/opt/buildagent/work/5c3cd640ded15833/addons/binding/org.openhab.binding.airquality/src/sat/binding.properties' was not found with resourceLoader org.codehaus.plexus.resource.loader.URLResourceLoader.
[14:18:45][Step 2/5] [DEBUG] The resource '/opt/buildagent/work/5c3cd640ded15833/addons/binding/org.openhab.binding.airquality/src/sat/binding.properties' was not found with resourceLoader org.codehaus.plexus.resource.loader.JarResourceLoader.
[14:18:45][Step 2/5] [DEBUG] The resource '/opt/buildagent/work/5c3cd640ded15833/addons/binding/org.openhab.binding.airquality/src/sat/binding.properties' was not found with resourceLoader org.codehaus.plexus.resource.loader.FileResourceLoader.
[14:18:45][Step 2/5] Failed to execute goal org.openhab.tools:static-code-analysis:0.0.4:checkstyle (default) on project org.openhab.binding.airquality: Unable to execute mojo
[14:18:45][Step 2/5] [INFO] ------------------------------------------------------------------------
[14:18:45][Step 2/5] [INFO] BUILD FAILURE
[14:18:45][Step 2/5] [INFO] Total time: 17.442 s
[14:18:45][Step 2/5] [INFO] Finished at: 2017-04-11T14:18:45+00:00
[14:18:45][Step 2/5] [INFO] Final Memory: 41M/432M
[14:18:45][Step 2/5] [WARNING] The requested profile "checks" could not be activated because it does not exist.
[14:18:45][Step 2/5] [ERROR] Failed to execute goal org.openhab.tools:static-code-analysis:0.0.4:checkstyle (default) on project org.openhab.binding.airquality: Unable to execute mojo: An error has occurred in Checkstyle report generation. Failed during checkstyle execution: Failed to get overriding properties: Could not find resource '/opt/buildagent/work/5c3cd640ded15833/addons/binding/org.openhab.binding.airquality/src/sat/binding.properties'. -> [Help 1]
[14:18:45][Step 2/5] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.openhab.tools:static-code-analysis:0.0.4:checkstyle (default) on project org.openhab.binding.airquality: Unable to execute mojo
[14:18:45][Step 2/5] at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
[14:18:45][Step 2/5] Caused by: org.apache.maven.plugin.MojoExecutionException: Unable to execute mojo
[14:18:45][Step 2/5] at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojo(MojoExecutor.java:96)
[14:18:45][Step 2/5] ... 20 more
[14:18:45][Step 2/5] Caused by: org.apache.maven.plugin.MojoExecutionException: An error has occurred in Checkstyle report generation.
[14:18:45][Step 2/5] at org.apache.maven.reporting.AbstractMavenReport.execute(AbstractMavenReport.java:171)
[14:18:45][Step 2/5] ... 24 more
[14:18:45][Step 2/5] Caused by: org.apache.maven.reporting.MavenReportException: Failed during checkstyle execution
[14:18:45][Step 2/5] at org.apache.maven.plugin.checkstyle.AbstractCheckstyleReport.executeReport(AbstractCheckstyleReport.java:492)
[14:18:45][Step 2/5] ... 26 more
[14:18:45][Step 2/5] Caused by: org.apache.maven.plugin.checkstyle.exec.CheckstyleExecutorException: Failed to get overriding properties
[14:18:45][Step 2/5] at org.apache.maven.plugin.checkstyle.exec.DefaultCheckstyleExecutor.getOverridingProperties(DefaultCheckstyleExecutor.java:585)
[14:18:45][Step 2/5] ... 29 more
[14:18:45][Step 2/5] Caused by: org.codehaus.plexus.resource.loader.ResourceNotFoundException: Could not find resource '/opt/buildagent/work/5c3cd640ded15833/addons/binding/org.openhab.binding.airquality/src/sat/binding.properties'.
[14:18:45][Step 2/5] at org.codehaus.plexus.resource.DefaultResourceManager.getResource(DefaultResourceManager.java:173)
[14:18:45][Step 2/5] ... 32 more
[14:18:45][Step 2/5] [ERROR] For more information about the errors and possible solutions, please read the following articles:
[14:18:45][Step 2/5] [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[14:18:45][Step 2/5] Process exited with code 1
Locally it also fails at airquality but with less usefull error:
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:1.0.0:compile (default-compile) on project org.openhab.binding.airquality: Compilation failure -> [Help 1]
[ERROR]
[ERROR]
Debug:
[DEBUG] Output directory: D:\Java\eclipse\openhab\git\openhab2-addons\addons\binding\org.openhab.binding.airquality\target\classes
[WARNING] Parameter 'useProjectSettings' is set to true, but preferences file 'D:\Java\eclipse\openhab\git\openhab2-addons\addons\binding\org.openhab.binding.airquality\.settings\org.eclipse.jdt.core.prefs' could not be found!
[DEBUG] Classpath:
[DEBUG] D:\Java\eclipse\openhab\git\openhab2-addons\addons\binding\org.openhab.binding.airquality\target\classes
[DEBUG] D:\system\users\vanWingerden\.m2\repository\p2\osgi\bundle\com.google.gson\2.5.0\com.google.gson-2.5.0.jar[+com/google/gson/*;+com/google/gson/annotations/*;?**/*]
[DEBUG] D:\system\users\vanWingerden\.m2\repository\p2\osgi\bundle\com.google.guava\10.0.1.v201203051515\com.google.guava-10.0.1.v201203051515.jar[+com/google/common/collect/*;?**/*]
[DEBUG] D:\system\users\vanWingerden\.m2\repository\p2\osgi\bundle\org.apache.commons.io\2.2.0.v201405211200\org.apache.commons.io-2.2.0.v201405211200.jar[+org/apache/commons/io/*;?**/*]
[DEBUG] D:\system\users\vanWingerden\.m2\repository\p2\osgi\bundle\org.apache.commons.lang\2.6.0.v201404270220\org.apache.commons.lang-2.6.0.v201404270220.jar[+org/apache/commons/lang/*;?**/*]
[DEBUG] D:\system\users\vanWingerden\.m2\repository\org\eclipse\smarthome\config\org.eclipse.smarthome.config.core\0.9.0-SNAPSHOT\org.eclipse.smarthome.config.core-0.9.0-SNAPSHOT.jar[+org/eclipse/smarthome/config/core/*;?**/*]
[DEBUG] D:\system\users\vanWingerden\.m2\repository\org\eclipse\smarthome\core\org.eclipse.smarthome.core.thing\0.9.0-SNAPSHOT\org.eclipse.smarthome.core.thing-0.9.0-SNAPSHOT.jar[+org/eclipse/smarthome/core/thing/*;+org/eclipse/smarthome/core/thing/binding/*;+org/eclipse/smarthome/core/thing/binding/builder/*;+org/eclipse/smarthome/core/thing/type/*;?**/*]
[DEBUG] D:\system\users\vanWingerden\.m2\repository\org\eclipse\smarthome\core\org.eclipse.smarthome.core\0.9.0-SNAPSHOT\org.eclipse.smarthome.core-0.9.0-SNAPSHOT.jar[+org/eclipse/smarthome/core/library/types/*;+org/eclipse/smarthome/core/types/*;?**/*]
[DEBUG] D:\system\users\vanWingerden\.m2\repository\p2\osgi\bundle\org.slf4j.api\1.7.2.v20121108-1250\org.slf4j.api-1.7.2.v20121108-1250.jar[+org/slf4j/*;?**/*]
[DEBUG] Source roots:
[DEBUG] D:\Java\eclipse\openhab\git\openhab2-addons\addons\binding\org.openhab.binding.airquality\src\main\java
[INFO] Using Groovy-Eclipse compiler to compile both Java and Groovy files
[DEBUG] Compiling 11 source files to D:\Java\eclipse\openhab\git\openhab2-addons\addons\binding\org.openhab.binding.airquality\target\classes
[WARNING] Found 0 errors and 0 warnings.
[INFO] Reactor Summary:
[INFO]
[INFO] openHAB 2 Add-ons .................................. SUCCESS [ 1.866 s]
[INFO] openHAB Add-ons .................................... SUCCESS [ 0.033 s]
[INFO] openHAB Bindings ................................... SUCCESS [ 0.065 s]
[INFO] AirQuality Binding ................................. FAILURE [ 1.846 s]
[INFO] AllPlay Binding .................................... SKIPPED
[INFO] Amazon Dash Button Binding ......................... SKIPPED
[INFO] Astro Binding ...................................... SKIPPED
[INFO] Atlona Binding ..................................... SKIPPED
[INFO] Autelis Binding .................................... SKIPPED
[INFO] AVM FRITZ! Binding ................................. SKIPPED
[INFO] BoschIndego Binding ................................ SKIPPED
[INFO] Chromecast Binding ................................. SKIPPED
[INFO] CoolMasterNet Binding .............................. SKIPPED
[INFO] DSCAlarm Binding ................................... SKIPPED
[INFO] Exec Binding ....................................... SKIPPED
[INFO] openHAB I/O Add-Ons ................................ SKIPPED
[INFO] Transport Feed bundle .............................. SKIPPED
[INFO] Feed Binding ....................................... SKIPPED
[INFO] Feed Binding Tests ................................. SKIPPED
[INFO] Folding Binding .................................... SKIPPED
[INFO] Freebox Binding .................................... SKIPPED
[INFO] Gardena Binding .................................... SKIPPED
[INFO] HarmonyHub Binding ................................. SKIPPED
[INFO] HDanywhere Binding ................................. SKIPPED
[INFO] Hunter Douglas PowerView Binding ................... SKIPPED
[INFO] Homematic Binding .................................. SKIPPED
[INFO] GlobalCache Binding ................................ SKIPPED
[INFO] IPP Binding ........................................ SKIPPED
[INFO] Keba Binding ....................................... SKIPPED
[INFO] Kodi Binding ....................................... SKIPPED
[INFO] Kostal Binding ..................................... SKIPPED
[INFO] LG TV Serial Binding ............................... SKIPPED
[INFO] Lutron Binding ..................................... SKIPPED
[INFO] MAX! Binding ....................................... SKIPPED
[INFO] MAX! Binding Tests ................................. SKIPPED
[INFO] meteostick Binding ................................. SKIPPED
[INFO] Miele Binding ...................................... SKIPPED
[INFO] Milight Binding .................................... SKIPPED
[INFO] Minecraft Binding .................................. SKIPPED
[INFO] Netatmo Binding .................................... SKIPPED
[INFO] Network Binding .................................... SKIPPED
[INFO] Oceanic Binding .................................... SKIPPED
[INFO] Onkyo Binding ...................................... SKIPPED
[INFO] OpenSprinkler Binding .............................. SKIPPED
[INFO] Orvibo Binding ..................................... SKIPPED
[INFO] PioneerAvr Binding ................................. SKIPPED
[INFO] Pulseaudio Binding ................................. SKIPPED
[INFO] RME Binding ........................................ SKIPPED
[INFO] Rfxcom Binding ..................................... SKIPPED
[INFO] Rfxcom Binding Tests ............................... SKIPPED
[INFO] Russound Binding ................................... SKIPPED
[INFO] SamsungTV Binding .................................. SKIPPED
[INFO] Silvercrest Wifi Socket Binding .................... SKIPPED
[INFO] SMA EnergyMeter Binding ............................ SKIPPED
[INFO] SqueezeBox Binding ................................. SKIPPED
[INFO] Systeminfo Binding ................................. SKIPPED
[INFO] Systeminfo Binding Test ............................ SKIPPED
[INFO] Tellstick Binding .................................. SKIPPED
[INFO] Tesla Binding ...................................... SKIPPED
[INFO] Toon Binding ....................................... SKIPPED
[INFO] Somfy URTSI II binding ............................. SKIPPED
[INFO] Vitotronic Binding ................................. SKIPPED
[INFO] WiFiLED Binding .................................... SKIPPED
[INFO] YamahaReceiver Binding ............................. SKIPPED
[INFO] ZoneMinder Binding ................................. SKIPPED
[INFO] ZWay Binding ....................................... SKIPPED
[INFO] openHAB Cloud Connector ............................ SKIPPED
[INFO] Hue Emulation Service .............................. SKIPPED
[INFO] ImperiHome Integration Service ..................... SKIPPED
[INFO] HomeKit Integration ................................ SKIPPED
[INFO] openHAB UI Components .............................. SKIPPED
[INFO] openHAB CometVisu Backend .......................... SKIPPED
[INFO] PHP Support for the CometVisu Backend .............. SKIPPED
[INFO] openHAB Voice Add-Ons .............................. SKIPPED
[INFO] Mary TTS Integration ............................... SKIPPED
[INFO] VoiceRSS TTS Integration ........................... SKIPPED
[INFO] openHAB Features ................................... SKIPPED
[INFO] openHAB Feature Addons External .................... SKIPPED
[INFO] openHAB 2 Feature Addons ........................... SKIPPED
[INFO] openHAB 2 Feature Verification ..................... SKIPPED
[INFO] Total time: 02:24 min
[INFO] Finished at: 2017-04-11T22:04:59+02:00
[INFO] Final Memory: 77M/528M
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:1.0.0:compile (default-compile) on project org.openhab.binding.airquality: Compilation failure
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.classworlds.Launcher.main(Launcher.java:47)
Caused by: copied.org.apache.maven.plugin.CompilationFailureException: Compilation failure
at copied.org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:420)
at org.eclipse.tycho.compiler.AbstractOsgiCompilerMojo.execute(AbstractOsgiCompilerMojo.java:293)
... 21 more
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
Do you have the same problems? If not any idea’s what could be wrong at my side?
