Issue of the topic: Cannot build, pom.xml not found / fields missing
If logs where generated please post these here using code fences:
[ERROR] \pom.xml:[0] Missing pom.xml file.
[WARNING] OH-INF.config.i18n.xml:[0]
Unused configuration reference with uri - system:i18n
[WARNING] OH-INF.config.networkinterface.xml:[0]
Unused configuration reference with uri - system:network [ERROR] null\pom.xml:[0] Missing /project/version in the pom.xml file.
Missing /project/artifactId in the pom.xml file. [INFO] Detailed report can be found at: file:/C:/proj/openhab/openhab-core/bundles/org.openhab.core/target/code-analysis/report.html
There is a test failing on master (which I skipped for now) and there are line ending problems on few xml files, which I do need to figure out more about. git with autocrlf normally works for me on Windows. There are format errors mvn spotless:apply needs to fix, but fixing them does not help.
@matt1 could you try to build the current master of openhab-core?
And if successful, can you share the exact JVM (Oracle, Azul, Redhat) + version and architecture (x86 / x64) and Maven version you are using?
Please also share your .gitconfig (make sure you leave personal things like your email address out if present), relevant environment variables (MAVEN_OPTS=-Xms512m -Xmx1024m) and the command your are using (mvn clean install)
It seems if you checkout pom files with Linux \n file endings on Windows maven finds the file invalid (which I can imagine), but if you checkout with Windows line endings \r\n spotless does find the file invalid.
There is also a failing test (at least on Windows):
[INFO] Running org.openhab.core.util.UIDUtilsTest
in: test
encoded: test
decoded: test
equals: true
in: TEST
encoded: TEST
decoded: TEST
equals: true
in: test123TEST
encoded: test123TEST
decoded: test123TEST
equals: true
in: test_test-test%test
encoded: test_5Ftest_2Dtest_25test
decoded: test_test-test%test
equals: true
in: äöø?
encoded: _C3_A4_C3_B6_C3_B8_E2_82_AC
decoded: äöø?
equals: true
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 s - in org.openhab.core.util.UIDUtilsTest
[INFO]
[INFO] Results:
[INFO]
[ERROR] Failures:
[ERROR] ByteArrayFileCacheTest.testGetFileExtension:86
Expected: is null
but: was "/var/log/openhab/"
[INFO]
[ERROR] Tests run: 589, Failures: 1, Errors: 0, Skipped: 0
[INFO]
