So I finally got around to trying a setup with the new 2.5.x distribution.
And the first thing I noticed is that the Karaf console output from bundle:list, is no longer usable. I don’t know when this changed, but there needs to be a way to get the old output instead of this.
209 │ Active │ 80 │ 2.5.0 │ openHAB UI :: Bundles :: HABPan
218 │ Active │ 80 │ 2.5.0 │ openHAB Add-ons :: Bundles :: T
219 │ Active │ 80 │ 1.1.1.201605111122 │ Swagger Provider
I looked through the help for the command, but didn’t find anything.
No, that‘s what is defined in our xml files. Changes appeared after switching to bnd build system. Don‘t know, but I think it can be changed to old syntax.
I tend to use la -l command for most of the time as it gives me exactly what I need - precise artifact coordinates without a text label relevant for users but not that much for developers.
If you don’t like location (-l) you can try to use symbolic name (-s) which will give you more compacted output.
