I am trying to develop a 1.x binding for MBus communication. However, I am getting the following exception while trying to provide BindingProvider:
!ENTRY org.eclipse.smarthome.model.core 4 0 2018-05-15 16:32:19.019
!MESSAGE [org.eclipse.smarthome.folder(240)] The activate method has thrown an exception
!STACK 0
java.lang.AbstractMethodError: org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Lorg/eclipse/smarthome/config/core/Configuration;)V
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:361)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:330)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:204)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:397)
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301)
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:123)
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:227)
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.addModelsToRepo(FolderObserver.java:174)
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.activate(FolderObserver.java:118)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229)
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39)
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650)
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506)
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307)
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:749)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430)
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390)
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265)
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254)
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227)
at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:187)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStart(Module.java:578)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1628)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1608)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1579)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1522)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Here is the GenericBindingProvider’s processBindingConfiguration
function definition-
@Override
public void processBindingConfiguration(String context, Item item, String bindingConfig) throws BindingConfigParseException
super.processBindingConfiguration(context, item, bindingConfig);
logger.debug("\n\n[ processBindingConfiguration ]\n\n".toUpperCase());
logger.debug("\n\n[ bindingConfig ] : {}", bindingConfig);
if (bindingConfig != null)
MBusBindingConfig config = new MBusBindingConfig(item, bindingConfig);
addBindingConfig(item, config);
I would love to get 1.x binding development guides. Any help will be very much appreciated.
