i’m a real beginner on Openhab 2. I already struggled with the Openhabian “magic” of installing. I tried it 2 times on my RPI 2 but i didn’t get it to work. Since my knowledge of the whole Linux world is quite limited, i didn’t dig deeper into it. Instead i installed it manually and thanks to the good instructions it now works.
My next step is to get my Busware SCC to work with my Homematic components. I already had it running with FHEM, but how does it work with OH 2? How can i pull up Pin 17 on the GPIO? The Busware instruction says:
By default the radio is held in RESET which is connected to GPIO17. You need explicitly pull GPIO17 HIGH to un-reset the radio:
if test ! -d /sys/class/gpio/gpio17; then echo 17 > /sys/class/gpio/export; fi
echo out > /sys/class/gpio/gpio17/direction
echo 1 > /sys/class/gpio/gpio17/value
Similar to FHEM i put this into /etc/init.d/openhab2. But still the Homematic Binding doesn’t find any components.
Can anybody please help on this?
Regards,
Dieter
