I have some Timing issues with KEY Inputs.
My setup is quite simple. I have installed openhabian and homegear on a Raspberry PI 3 and connected a Homatic wired bus (RS485) with an external USB to RS485 converter to homegear. In the Paper UI I setup the Homematic Binding and also the Things and Items. Everything works fine. I created a simple rule txt file in the rules Folder that has one very simple rule:
rule "Relais schalten"
Item Office_1_PS1 changed to ON
if(Office_1_REL1.state != ON) {
sendCommand(Office_1_REL1, ON)
else {
sendCommand(Office_1_REL1, OFF)
that just toggles an relay by pushing a button. That works very well.
My problem is that the button is locked for about 2s each time I push it. The Events.log file Shows the behaviour:
2018-06-03 22:11:45.478 [vent.ItemStateChangedEvent] - Office_1_PS1 changed from OFF to ON 2018-06-03 22:11:45.491 [vent.ChannelTriggeredEvent] - homematic:HG-HMW-IO-12-Sw7-DR:12f88c10:OEQ08xxxxx:1#PRESS triggered SHORT 2018-06-03 22:11:45.500 [ome.event.ItemCommandEvent] - Item ‘Office_1_REL1’ received command ON 2018-06-03 22:11:45.515 [vent.ItemStateChangedEvent] - Office_1_REL1 changed from OFF to ON 2018-06-03 22:11:45.772 [vent.ChannelTriggeredEvent] - homematic:HG-HMW-IO-12-Sw7-DR:12f88c10:OEQ08xxxxx:1#PRESS triggered SHORT 2018-06-03 22:11:47.778 [vent.ItemStateChangedEvent] - Office_1_PS1 changed from ON to OFF
Description:
At 22:11:45.478 I push the button on the Homematic Wired Module.
At 22:11:45.515 the Relay on the Homematic Wired Module is turned on
At 22:11:45.772 I released the button on the Homematic Wired Module
But only 2 seconds later at 22:11:47.778 the button is again released so that I can again trigger on the ON-Event in my rule.
This behaviour can also be seen in the “Control” section of the Paper UI.
Is there a possibility to minimize the delay or to turn it off? I would like to push the button and react on the button very quickly.
You wäre Wright, but if I want to switch the relay back again within 2s it is not possible because the push button state is still ON and the rule does not Fire. After 2s I can switch the Relay again because the internal state of the button is again OFF and I can trigger on the OFF to ON transition again.
This is due to your hardware. The switch it self send 2 ON updates and then an OFF update after 2 seconds. Maybe the switch config can be changed or the firmware updated.
Thank you for your Reply but I don’t think that the Hardware sends the “OFF” state that late. I again performed a smal test and attached the log files:
OpenHAB Events.log:
1 2018-06-04 17:46:36.403 [vent.ChannelTriggeredEvent] - homematic:HG-HMW-IO-12-Sw7-DR:12f88c10:OEQ0862609:1#PRESS triggered SHORT
2 2018-06-04 17:46:36.411 [vent.ItemStateChangedEvent] - Office_1_PS1 changed from OFF to ON
3 2018-06-04 17:46:36.647 [vent.ChannelTriggeredEvent] - homematic:HG-HMW-IO-12-Sw7-DR:12f88c10:OEQ0862609:1#PRESS triggered SHORT
4 2018-06-04 17:46:36.702 [ome.event.ItemCommandEvent] - Item 'Office_1_REL1' received command ON
5 2018-06-04 17:46:36.711 [vent.ItemStateChangedEvent] - Office_1_REL1 changed from OFF to ON
6 2018-06-04 17:46:38.653 [vent.ItemStateChangedEvent] - Office_1_PS1 changed from ON to OFF
Homegear.log:
1 06/04/18 17:46:36.382 HomeMatic Wired packet received: FDFFFFFFFF980001B3D2064B0000CEEF68
2 06/04/18 17:46:36.383 Module HomeMatic Wired: Info: PRESS_SHORT of HomeMatic Wired peer 1 with serial number OEQ0862609:1 was set to 0x33.
3 06/04/18 17:46:36.399 HomeMatic Wired packet received: FDFFFFFFFF9A0001B3D2124100120003064F455130383632363039F3D6
4 06/04/18 17:46:36.638 HomeMatic Wired packet received: FDFFFFFFFF9C0001B3D2064B0000D2CD42
5 06/04/18 17:46:36.638 Module HomeMatic Wired: Info: PRESS_SHORT of HomeMatic Wired peer 1 with serial number OEQ0862609:1 was set to 0x34.
6 06/04/18 17:46:36.670 HomeMatic Wired packet received: FDFFFFFFFF9E0001B3D2124100120003064F45513038363236303901A0
7 06/04/18 17:46:36.708 RPC Server (Port 2001): Info: Client number 9297 is calling RPC method: setValue (2) Parameters:
8 (String) OEQ0862609:13
9 (String) STATE
10 (Boolean) 1
11 06/04/18 17:46:36.709 Module HomeMatic Wired: RS485 Module "CTI-RS485": Info: Sending: FD0001B3D21A0000000105780CC8D224
12 06/04/18 17:46:36.734 HomeMatic Wired packet received: FD00000001380001B3D206690CC800D176
13 06/04/18 17:46:36.734 Module HomeMatic Wired: Info: STATE of HomeMatic Wired peer 1 with serial number OEQ0862609:13 was set to 0xC8.
14 06/04/18 17:46:36.734 Module HomeMatic Wired: Info: WORKING of HomeMatic Wired peer 1 with serial number OEQ0862609:13 was set to 0x00.
15 06/04/18 17:46:36.753 Module HomeMatic Wired: RS485 Module "CTI-RS485": Info: Sending: FD0001B3D21900000001020C4E
Here you can see that in the Homegear.log file line 1 the button was pressed at 17:46:36.382 and in line 2 Homegear creates the info that the button 1 received the PRESS_SHORT event.
openHAB is creating the …TriggerEvent (line 1 of the openHAB Events) and than in line 2 creates …ChangeEvent where the Item Office_1_PS1 is changed from OFF to ON.
In line 4 to 6 of the homegear log file it is logged that the button is released again (~300ms later). This action is registered in the openHAB events.log file in line 3.
In line 4 of the openHAB events.log file the state of the relay is set to ON.
This state Change is processed in the homegear.log file in lines 7 to 15.
So everything is very quick within about 400ms! Perfect!!!
BUT than, and that can be seen in line 6 of the openHAB events file the state of the Item “Office_1_PS1” is changed from ON to OFF about 2 seconds later. And it is alway about 2 seconds later so it can’t be a performance problem in openHAB or the Raspberry PI.
In my opinion this state change must take place when the …TriggerEvent in line 3 of the openHAB events file had been received and not 2 seconds later.
rule "Relais 1 toggeln"
else {
Office_1_PS1.sendCommand(OFF)
Then it works as expected - I can toggle the relay between ON and OFF very quickly. So I manually reset the state of the button in my rule…
But if I do it that way, the “LONG_PRESS” with the button does not work any longer
So isn’t there a possibility to decrease the mentioned time of 2 seconds to let me say 0.5 seconds? Somewhere in the configuration of openHAB?
with the Paper UI and checked that the 2 delays, that can be configured are set to 0. The item Office_1_PS1 is configured as switch.
I already tried to set the two delays (If I can remember one delay was for incoming and one delay was for the posting of events) in the configuration to 1 or 0.5s because sometimes 0 means “default” and I thought that default could be 2s but that doesn’t help either.
Tonight I can post a screenshot of the configuration and I will try to set up the system by textfiles only not using the Paper UI. I read a lot of posts where at least user got there problems solved by using the text configuration with the .items, .sitemap files etc.only and not using the Paper UI.
I now reinstalled everything starting at openhabian. I installed the Homematic Binding with the PaperIU and created the .things, .items and .rules files from scratch.
Outcome: Same behaviour as setting up the system with the Paper UI…
Now it seems to me that this behaviour is in the homematic binding. So no way to change it?
