Hi, I implemented a back button the following way:
in conf/html insert habpanel_widget_backbutton.js with the following content:
angular.module("backButton", [])
.directive("backButton", ["$window", function ($window) {
return {
restrict: "A",
link: function (scope, elem, attrs) {
elem.bind("click", function () {
$window.history.back();
Then create a custom widget with the following content:
<div style="position: absolute; top: 0; left: 0; width: 100%; height: 100%;
display: flex; margin: 0; padding: 0; overflow:hidden"
oc-lazy-load="['/static/habpanel_widget_backbutton.js']">
<button back-button style="width: 100%; display: flex;
align-items: center;
justify-content: center;
border: none;
background-color: #223344;">
<img src="../images/classic/goback.svg"></img>
</button>
</div>
Here, the goback.svg image is placed in the folder icons/classic.
The goback.svg file has the following content:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
<!-- Creator: CorelDRAW X8 -->
<svg xmlns="http://www.w3.org/2000/svg" xml:space="preserve" width="64px" height="64px" version="1.1" style="shape-rendering:geometricPrecision; text-rendering:geometricPrecision; image-rendering:optimizeQuality; fill-rule:evenodd; clip-rule:evenodd"
viewBox="0 0 6400000 6400000"
xmlns:xlink="http://www.w3.org/1999/xlink">
<defs>
<style type="text/css">
<![CDATA[
.str0 {stroke:black;stroke-width:199963;stroke-linejoin:round}
.fil1 {fill:none}
.fil0 {fill:white}
</style>
</defs>
<g id="Ebene_x0020_1">
<metadata id="CorelCorpID_0Corel-Layer"/>
<g>
<path class="fil0" d="M104056 3241457c0,-43347 17717,-84450 48781,-114686l3194212 -2936375c58820,-57284 133112,-56221 183073,-35670 49961,20552 103230,70277 103230,150238l0 990367c0,149175 124371,270358 277562,270358l2218610 0c92127,0 166420,72402 166420,162167l0 3027203c0,89646 -74411,162167 -166538,162167l-2219673 0c-153191,0 -277562,121064 -277562,270239l118 991430c0,79962 -53269,129687 -103230,150238 -49961,20551 -123190,21614 -180947,-35670l-3196457 -2938500c-31063,-29174 -47717,-70277 -47717,-113506l118 0zm0 0l0 0 0 0z"/>
</g>
</g>
</svg>
It works for me so far, maybe somebody finds a better way.
