I’ve just upgraded from 2.3 to 2.4 and my two motion sensors display OK and ALARM buttons instead of the switch as they had before the upgrade. I’d rather have the switch. I’ve seen in the docs how to display buttons, but nothing that explains how to get the switch. From the docs it seems that the default is to display a switch and mappings are used to display buttons. Here is my sitemap entry for one of the sensors:
BasicUI is what I was referring to, but I just checked ClassicUI and there are buttons displayed there as well. I have never used a mapping for buttons, anywhere on my sitemap, so I’m at a loss.
Totally magical. Adding the extra sitemap line should have busted any caching. I cannot think of any way for UI to pluck button names from thin air, there’s a hidden mapping at work somewhere!
channels can come with labels but the Item label is supposed to override that.
Could try sitemap, to see what will override -
Bearing this is mind, we should also note that for zwave it was advised - This binding will require that existing things are deleted, and re-added so that the binding picks up the latest thing definitions .
I wonder if this device has changed from switch to contact model
I have simular situation on my three z-wave motion sensors. And it changed when updating z-wave binding to 2.5. I did deleted my devices and re-added them again.
items file
Switch Node10_BinarySensor "Vision PIR Binary Sensor [%s]" <cum_motion> (gMotion) {channel="zwave:device:512:node10:sensor_binary"}
Switch ZWaveNode5ZW100MultiSensor6_MotionAlarm "Multisensor6 PIR Alarm [%s]" <cum_motion> (gMotion) {channel="zwave:device:512:node5:alarm_motion"}
Switch Node13_AlarmBurglar "Neo Coolcam PIR Alarm (burglar) [%s]" <cum_motion> (gMotion) {channel="zwave:device:512:node13:alarm_motion"}
Good, in a way @lorenzopt will be pleased to know his system has not gone rogue.
Perhaps it is time to summon @chris he may have missed this thread with no zwave tag?
Seeing the [%s] is interesting, it’s no longer ON/OFF is it? I guess the UI auto produces the buttons instead of a slider when the state is given to it as e.g. “untriggered”.
This is all a bit like UoM for Numbers.
