i am struggling for 3 weeks and can find anything useful for calculating price of power consumption with Sonoff POWR2.
Everything would be OK with this rule:
rule “Price Boiler”
Item Sonoff_POWR2_Total received update
Price_Total.
postUpdate (Sonoff_POWR2_Total.state as DecimalType * 0.37629)
but problem is that in my country we have two tariff for power. Between 07-21 is higher price and between 21-07 is lower with 0.376.
Can anybody help me with new rule to calculate for eq. in night with lowerprice,and if works in day hours calculate with higher price, store these values and then sum it.
Try defining the time periods you need like below. Create an item for Price_Total_day and Price_Total_night.
rule “Price Boiler”
if(now.getHourOfDay > 7 || now.getHourOfDay < 21)
Price_Total_day.postUpdate (Sonoff_POWR2_Total.state as DecimalType * 0.57629) //need to adjust value for whatever the day rate is
else
Price_Total_night.postUpdate(Sonoff_POWR2_Total.state as DecimalType * 0.37629)
This is just an idea to help get you started not a complete solution. You’ll need a to create a Time cron rule, or something similar, for adding the totals. You may want to read up on persistence as you’ll need it to get a daily total.
You will have to add Power consumption to two different items (dependent on time of day). If the item is persisted, you could calculate the consumption within the low/high period, but This is only an option for maybe consumption today
if time is after 7 a.m and before 9 p.m.:
(total at 7 a.m. minus total at start of day)*lowPrice +
(total now minus total at 7 a.m.)*highPrice
Please be aware that getHourOfDay is 0 to 23, so highPrice time would be
I doubt that there is an option in Tasmota for doing that. As far as I understand, your Item Sonoff_POWR2_Total is an JSONPATH extraction of a tele topic? As this item is already a sum, how to do that job? Of course you can do it in openHAB for future data:
Number Sonoff_POWR2_Total { ... }
Number Sonoff_POWR2_Total_LowTariff
Number Sonoff_POWR2_Total_HighTariff
persist all three Items to rrd4j (everyMinute)
Rule:
rule "add high and low pow tariff"
Time cron "0 * * * * ?" // every Minute
val Number nOld = Sonoff_POWR2_Total.historicState(now.minusMinutes(1),"rrd4j").state as Number
val Number nNow = Sonoff_POWR2_Total.state as Number
val Number nConsumption = nNow - nOld
if(now.getMinuteOfDay > 7 * 60 && now.getMinuteOfDay < 21 * 60 + 1)
Sonoff_POWR2_Total_HighTariff.postUpdate(Sonoff_POWR2_Total_HighTariff.historicState(now.minusMinutes(1),"rrd4j").state as Number + nConsumption)
else
Sonoff_POWR2_Total_LowTariff.postUpdate(Sonoff_POWR2_Total_LowTariff.historicState(now.minusMinutes(1),"rrd4j").state as Number + nConsumption)
This will add the delta of Sonoff_POWR2_Total either to high or low tariff according to the time frame. Of course I don’t know how exact this calculation will be
Error during the execution of rule ‘add high and low pow tariff’: cannot invoke method public abstract org.eclipse.smarthome.core.types.State org.eclipse.smarthome.core.persistence.HistoricItem.getState() on null
Try also this, but is the same:
rule “test”
Item Sonoff_POWR2_Switch changed to ON
time_play_started = now
logInfo(“test”," HistoricalState 1: " + Sonoff_POWR2_Total.historicState(now.minusDays(1),“rrd4j”).state)
As you are using rrd4j, please be aware that you have to use everyMinute as strategy.
Using * as items list will persist every Item, I don’t know how large the rrd file per item is (take a look at $OPENHAB_USERDATA/persistence/rrd4j/)
For a storage consuming persistence service it’s better to define only the items which you need to be persisted.
