Hello
I manage to use this code for a TV, which is plugged in a strip.
Now I want to find a solution for all 3 sockets from the strip. Can this be done with members? Or should i create 2 times more the rule?
my rule:
import java.lang.Math
var org.joda.time.DateTime whenStarted = null
rule “LGTV started”
Item TellurPowerStripTellurPower1 received command ON
whenStarted = now
rule “LGTV stopped”
Item TellurPowerStripTellurPower1 received command OFF
if(whenStarted != null) {
// do the same as the if(TellurPowerStripTellurPower1.state == ON && whenStarted != null) in the increment rule
whenStarted = null
rule “Increment LGTV Runtimes”
Time cron “* */1 * * * ?”
if(TellurPowerStripTellurPower1.state == ON && whenStarted != null){
logInfo(“GenUptime”, “LGTV: Getting now”)
val long nowMsec = now.millis
logInfo("GenUptime", "LGTV: Getting whenStarted")
val long wsMsec = whenStarted.millis
logInfo("GenUptime", "LGTV: Resetting whenStarted")
whenStarted = now
logInfo("GenUptime", "LGTV: Calculating time difference")
val long timeSinceLastUpdate = nowMsec - wsMsec
logInfo("GenUptime", "LGTV: Getting total Uptime in msec")
//val long oldVal = TellurPowerStripTellurPower1RuntimeMSec.state
val long oldVal = if(TellurPowerStripTellurPower1RuntimeMSec.state === NULL) 0 else (TellurPowerStripTellurPower1RuntimeMSec.state as Number).longValue
//logInfo("GenUptime", "Adding current time to total")
logInfo("GenUpTime", "LGTV: Adding current time to total: timeSinceLastUpdate = " + timeSinceLastUpdate + " oldVal = " + oldVal)
val long totalMsec = oldVal + timeSinceLastUpdate // calculate total runtime
logInfo("GenUptime", "LGTV: Posting totalMsec to Item")
TellurPowerStripTellurPower1RuntimeMSec.postUpdate(totalMsec) // post the full runtime
logInfo("GenUptime", "LGTV: Calculating hours")
//val long hours = Math::round(totalMsec/1000/60/60)
val double hours = totalMsec/1000.0/60.0/60.0
logInfo("GenUptime", "LGTV: Posting hours")
TellurPowerStripTellurPower1RuntimeHours.postUpdate(hours)
logInfo("GenUptime", "LGTV: Calculate energy consumption")
var float LGTVPower = 130 // Enter total power consumption [in Watts]
val double LGTVEnergyConsumption = hours * LGTVPower / 1000 // Energy consumed [kWh] Energy = Power * Time
LGTVEnergy.postUpdate(LGTVEnergyConsumption)
else if(TellurPowerStripTellurPower1.state == ON && whenStarted == null){
logInfo("GenUptime", "LGTV: TV is ON but 'LGTV started' rule never executed")
whenStarted = now
else {
logInfo("GenUptime", "LGTV is not running")
items:
Switch TellurPowerStripTellurPower1 “On/off switch” (gTellur) [“Outlet”] {channel=“mqtt:topic:46425acf:Tellur_Strip:Tellur_Power1”}
Switch TellurPowerStripTellurPower2 “On/off switch” (gTellur) [“Outlet”] {channel=“mqtt:topic:46425acf:Tellur_Strip:Tellur_Power2”}
Switch TellurPowerStripTellurPower3 “On/off switch” (gTellur) [“Outlet”] {channel=“mqtt:topic:46425acf:Tellur_Strip:Tellur_Power3”}
Number LGTVEnergy “TV Socket1 Energy Consumption [%.2f kWh]” (gEnergyTellur)
Number TellurPowerStripTellurPower1RuntimeHours “LGTV Runtime Hours [%.2f Hours]”
Number TellurPowerStripTellurPower1RuntimeMSec "LGTV Runtime "
