Can I made a calculation in the sitemap configuration?
Like
Text item=(LR_Temperature-5) label="Livingroom [%.1f °C]"
Like
You can make an Item
and use a Rule
to calculate & set the Item. Display that Item
on your sitemap
Thought it might be possible with out a rule…
You could also look into transformations, a javascript transform allows arbitrary manipulations for display.
I really would not worry about that.
They have different effects; do you want to actually change the Item state, or only to massage it for display?
Another question is which would be easier to troubleshoot?
I found out with a calibrated device that my device is sending a 0.5°C to high temperature therefore I simply want to subtract 0.5 from this value to display it and save it to the database. The value is sent via mqtt.
So that means what is the best option
Assuming you mean using openHAB persistence, then you will have to adjust it in your Item’s state.
Have you seen the offset profile ?
