I have a DateTime item and now I want to check if the time stamp is more than half an hour ago.
The Designer says this is not possible (Cannot cast element of sealed type java.lang.String to org.joda.time.DateTime):
val DateTime timestamp = datetimeitem.state as DateTime
if( now.isAfter( datetimeitem.plusMinutes(30))) {
//dostuff
I’m working on an examples wiki page for a binding that has a little time logic in it, still a work in progress, but this would do it:
import org.joda.time.*
import org.openhab.core.library.types.*
var DateTime dateTime = new DateTime((datetimeitem.state as DateTimeType).calendar.timeInMillis)
if (dateTime.plusMinutes(30).isBefore(now)) {
// dostuff
I tried it and while it works in one rule, the Designer gives me errors in another one.
So I found a simpler way for measuring the time between to events:
var long last_change = now.millis
rule "duration"
Item item_which_duration_you_want_to_measure changed
//duration as Number in minutes
var Number min = ((now.millis - last_change) / 60000)
ts_state_change = now.millis
