Ok good to know.
I thought there should be a range of 10 days (for my configuration with 10 days preloadTime).
Could you may answer some questions/correct my assumptions regarding how the binding works.
The binding import all events from a given calender (past and future)
Afterwards it´s checking for events that are between now and the preloadTime
The first events will be stored and marked as eventNr:1
reloadInterval is the time between checks if there´s a new entry that wasn´t imported yet
How does the binding decide when to change the item to a new entry?
Then last thing is what´s currently not working as i think it should. The item is still at an old entry and the binding doesn´t load the next one as eventNr:1
Based on what I’ve seen from using the binding, the first 4 bullets are true.
Generally I think past events are not loaded, but processed and skipped as historic.
The default preloadTime is 24 hours.
As an example, this refresh occurred at 23:17, and loaded events from 23:17 to 24 hours later:
As to bullet 5, items should change when the scheduled event jobs are fired:
2019-01-06 23:17:30.377 [DEBUG] [.io.caldav.internal.CalDavLoaderImpl] - begin timer scheduled for event '50b9kr6mu1cqjtpkm9rofl6srt@google.com(We 3 kings@07.01.2019/10:00-07.01.2019/10:30)' @ Mon Jan 07 10:00:00 EST 2019
So an event should become current when it’s begin timer job runs.
I think I had the same issue as you. When I changed the item file in editor and saved it, the items got updated. I tried out a couple of things and I assume that it is working fine now for me. Only thing I did is to add the calender into the caldavPersonal.cfg file
Looks like this for me:
# Which calendars should be used to detect presence (comma separated)
caldavPersonal:usedCalendars=Muellkalender
I already have this entry in my caldavpersonal.cfg
Thanks for the hint!
Today is an event day, so let´s see if the event changes tomorrow…
I had some sardine errors today for an event at 07-02-2019
2019-01-09 21:38:50.237 [WARN ] [caldav.internal.job.EventReloaderJob] - Sardine exception reading ics file: 4jqsclt17tlfm0odti8l55hdii_google_com
com.github.sardine.impl.SardineException: Unexpected response
at com.github.sardine.impl.handler.ValidatingResponseHandler.validateResponse(ValidatingResponseHandler.java:48) ~[267:org.openhab.io.caldav:1.13.0]
at com.github.sardine.impl.handler.VoidResponseHandler.handleResponse(VoidResponseHandler.java:34) ~[267:org.openhab.io.caldav:1.13.0]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:756) ~[267:org.openhab.io.caldav:1.13.0]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:741) ~[267:org.openhab.io.caldav:1.13.0]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:732) ~[267:org.openhab.io.caldav:1.13.0]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:145) ~[267:org.openhab.io.caldav:1.13.0]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:318) [267:org.openhab.io.caldav:1.13.0]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:137) [267:org.openhab.io.caldav:1.13.0]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Ok i´m out of ideas and going to uninstall caldav.
I´m not willing to spend anymore time with this binding.
It´s not loading any event from the calender and not even doing anything like the binding is freezed.
When trying to restart the bundle i just get a tone of errors and the status stays in Waiting
2019-01-15 18:56:02.669 [ERROR] [org.openhab.io.caldav ] - bundle org.openhab.io.caldav:1.13.0 (267)[org.openhab.io.caldav.caldavloader(318)] : Error during instantiation of the implementation object
java.lang.reflect.InvocationTargetException: null
at sun.reflect.GeneratedConstructorAccessor346.newInstance(Unknown Source) ~[?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:?]
at org.apache.felix.scr.impl.inject.ComponentConstructor.newInstance(ComponentConstructor.java:305) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:271) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) [39:org.apache.felix.scr:2.1.2]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:805) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:1) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:803) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:124) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:1) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:122) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) [?:?]
at org.apache.karaf.bundle.command.Start.executeOnBundle(Start.java:38) [42:org.apache.karaf.bundle.core:4.2.1]
at org.apache.karaf.bundle.command.BundlesCommand.doExecute(BundlesCommand.java:65) [42:org.apache.karaf.bundle.core:4.2.1]
at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) [42:org.apache.karaf.bundle.core:4.2.1]
at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) [14:org.apache.karaf.shell.core:4.2.1]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) [14:org.apache.karaf.shell.core:4.2.1]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) [14:org.apache.karaf.shell.core:4.2.1]
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) [14:org.apache.karaf.shell.core:4.2.1]
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) [14:org.apache.karaf.shell.core:4.2.1]
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) [14:org.apache.karaf.shell.core:4.2.1]
at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) [14:org.apache.karaf.shell.core:4.2.1]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) [14:org.apache.karaf.shell.core:4.2.1]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) [14:org.apache.karaf.shell.core:4.2.1]
Caused by: java.lang.IllegalStateException: something went wrong, the loader service should be singleton
at org.openhab.io.caldav.internal.CalDavLoaderImpl.<init>(CalDavLoaderImpl.java:102) ~[?:?]
... 83 more
2019-01-15 18:56:02.705 [WARN ] [org.openhab.io.caldav ] - FrameworkEvent WARNING - org.openhab.io.caldav
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:805) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry$1.run(ServiceRegistry.java:1) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:803) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:124) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:1) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:122) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.karaf.bundle.command.Start.executeOnBundle(Start.java:38) ~[?:?]
at org.apache.karaf.bundle.command.BundlesCommand.doExecute(BundlesCommand.java:65) ~[?:?]
at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) ~[?:?]
at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) ~[?:?]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) ~[?:?]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
at java.lang.Thread.run(Thread.java:748) ~[?:?]
2019-01-15 18:56:02.719 [ERROR] [org.openhab.io.caldav ] - bundle org.openhab.io.caldav:1.13.0 (267)[org.openhab.io.caldav.caldavloader(318)] : Error during instantiation of the implementation object
at org.apache.felix.metatype.internal.ManagedServiceTracker.addingService(ManagedServiceTracker.java:52) [2:org.apache.felix.metatype:1.2.0]
... 83 more
2019-01-15 18:56:02.780 [WARN ] [org.openhab.io.caldav ] - FrameworkEvent WARNING - org.openhab.io.caldav
at org.apache.felix.metatype.internal.ManagedServiceTracker.addingService(ManagedServiceTracker.java:52) ~[?:?]
2019-01-15 18:56:02.795 [ERROR] [org.openhab.io.caldav ] - bundle org.openhab.io.caldav:1.13.0 (267)[org.openhab.io.caldav.caldavloader(318)] : Error during instantiation of the implementation object
at org.apache.felix.cm.impl.helper.BaseTracker.getRealService(BaseTracker.java:207) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:102) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1102) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1058) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:126) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:123) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:122) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [9:org.apache.felix.configadmin:1.9.4]
... 28 more
2019-01-15 18:56:02.847 [ERROR] [org.openhab.io.caldav ] - bundle org.openhab.io.caldav:1.13.0 (267)[org.openhab.io.caldav.caldavloader(318)] : Error during instantiation of the implementation object
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [39:org.apache.felix.scr:2.1.2]
... 52 more
2019-01-15 18:56:02.863 [WARN ] [org.openhab.io.caldav ] - FrameworkEvent WARNING - org.openhab.io.caldav
at org.apache.felix.cm.impl.helper.BaseTracker.getRealService(BaseTracker.java:207) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:102) ~[?:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1102) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1058) ~[?:?]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:126) ~[?:?]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:123) ~[?:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:122) ~[?:?]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) ~[?:?]
