My fault, I have set TRACE for caldav_personal instead of io.caldav
2016-05-16 12:33:18.690 [DEBUG] [o.i.c.internal.CalDavActivator] - CalDav Calendar IO has been started.
2016-05-16 12:33:18.784 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: service.pid
2016-05-16 12:33:18.784 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: tasks:lastModifiedFileTimeStampValid
2016-05-16 12:33:18.800 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: tasks:password
2016-05-16 12:33:18.800 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: tasks:preloadTime
2016-05-16 12:33:18.815 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: tasks:reloadInterval
2016-05-16 12:33:18.815 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: tasks:url
2016-05-16 12:33:18.831 [TRACE] [.i.c.internal.CalDavLoaderImpl] - configuration parameter: tasks:username
2016-05-16 12:33:18.831 [TRACE] [.i.c.internal.CalDavLoaderImpl] - config for id ‘tasks’: CalDavConfig [key=tasks, username=michalXXXXXXX@gmail.com, password=XXXXXX, url=https://www.google.com/calendar/dav/michalXXXXXX@gmail.com/events, reloadMinutes=15, preloadMinutes=20000, disableCertificateVerification=false, lastModifiedFileTimeStampValid=false]
2016-05-16 12:33:18.862 [INFO ] [.service.AbstractActiveService] - CalDav Loader has been started
2016-05-16 12:33:18.878 [TRACE] [.i.c.internal.CalDavLoaderImpl] - starting execution…
2016-05-16 12:33:18.924 [INFO ] [.i.c.internal.CalDavLoaderImpl] - reload job scheduled for: tasks
2016-05-16 12:33:19.112 [TRACE] [.i.c.internal.CalDavLoaderImpl] - quering events for filter: CalDavQuery [calendarIds=[tasks], from=2016-05-16T12:33:19.049+02:00, to=null, sort=ASCENDING]
2016-05-16 12:33:19.112 [DEBUG] [.i.c.internal.CalDavLoaderImpl] - return event list for CalDavQuery [calendarIds=[tasks], from=2016-05-16T12:33:19.049+02:00, to=null, sort=ASCENDING] with 0 entries
2016-05-16 12:33:29.486 [TRACE] [.i.c.internal.CalDavLoaderImpl] - listeners for events: 1
2016-05-16 12:33:29.486 [DEBUG] [o.o.i.c.i.job.EventReloaderJob] - loading events for config: tasks
2016-05-16 12:33:32.091 [TRACE] [o.o.i.c.i.job.EventReloaderJob] - eventContainer found: true
2016-05-16 12:33:32.091 [TRACE] [o.o.i.c.i.job.EventReloaderJob] - last resource modification: 2016-05-16T12:33:32.091+02:00
2016-05-16 12:33:32.106 [TRACE] [o.o.i.c.i.job.EventReloaderJob] - last change of already loaded event: 2015-01-15T20:05:02.000+01:00
2016-05-16 12:33:32.106 [DEBUG] [o.o.i.c.i.job.EventReloaderJob] - loading resource: /calendar/dav/michalXXXXXXX@gmail.com/events/ac8cc55f-2346-496c-9563-c2ab114b4882.ics
2016-05-16 12:33:32.465 [TRACE] [o.o.i.c.i.job.EventReloaderJob] - loading event: ac8cc55f-2346-496c-9563-c2ab114b4882:Statt
2016-05-16 12:33:32.496 [TRACE] [o.o.i.c.i.job.EventReloaderJob] - eventContainer found: false
2016-05-16 12:33:32.512 [TRACE] [o.o.i.c.i.job.EventReloaderJob] - last resource modification: 2016-05-16T12:33:32.496+02:00
2016-05-16 12:33:32.512 [TRACE] [o.o.i.c.i.job.EventReloaderJob] - last change of already loaded event: null
2016-05-16 12:33:32.512 [DEBUG] [o.o.i.c.i.job.EventReloaderJob] - loading resource: /calendar/dav/michalXXXXXXX@gmail.com/events/c7gsve1p7kke2kifpukb5eokh0@google.com.ics
2016-05-16 12:33:32.808 [ERROR] [o.o.i.c.i.job.EventReloaderJob] - error while loading calendar entries: null
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:325) ~[na:na]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:282) ~[na:na]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:118) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
This one should be today in the evening
BEGIN:VEVENT
DTSTART;TZID=Europe/Warsaw:20151123T213000
DTEND;TZID=Europe/Warsaw:20151123T230000
RRULE:FREQ=WEEKLY;WKST=MO;UNTIL=20201123T203000Z;INTERVAL=1;BYDAY=MO
DTSTAMP:20160516T091642Z
UID:a2nrnbqa1pqmv29m15ag839qd0@google.com
CREATED:20151119T092913Z
DESCRIPTION:
LAST-MODIFIED:20151119T092913Z
SEQUENCE:1
STATUS:TENTATIVE
SUMMARY:Basen krynia
TRANSP:OPAQUE
BEGIN:VALARM
ACTION:DISPLAY
DESCRIPTION:This is an event reminder
TRIGGER:-P0DT0H15M0S
END:VALARM
END:VEVENT
