hi,
i successfully got the caldav binding up and running with my google calendar but since i like to be more independent i installed the baikal server on my openhabian setup.
\im able to connect to the baikal server from my android phone but not from openhabian.
error in log file:
09:15:55.137 [ERROR] [caldav.internal.job.EventReloaderJob] - error while loading calendar entries: Unexpected response (405 - Method Not Allowed )
com.github.sardine.impl.SardineException: Unexpected response (405 Method Not Allowed)
at com.github.sardine.impl.handler.ValidatingResponseHandler.validateResponse(ValidatingResponseHandler.java:48)[224:org.openhab.io.caldav:1.10.0.201704300110]
at com.github.sardine.impl.handler.MultiStatusResponseHandler.handleResponse(MultiStatusResponseHandler.java:40)[224:org.openhab.io.caldav:1.10.0.201704300110]
at com.github.sardine.impl.handler.MultiStatusResponseHandler.handleResponse(MultiStatusResponseHandler.java:35)[224:org.openhab.io.caldav:1.10.0.201704300110]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:218)[224:org.openhab.io.caldav:1.10.0.201704300110]
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:160)[224:org.openhab.io.caldav:1.10.0.201704300110]
at com.github.sardine.impl.SardineImpl.execute(SardineImpl.java:962)[224:org.openhab.io.caldav:1.10.0.201704300110]
at com.github.sardine.impl.SardineImpl.list(SardineImpl.java:417)[224:org.openhab.io.caldav:1.10.0.201704300110]
at com.github.sardine.impl.SardineImpl.list(SardineImpl.java:409)[224:org.openhab.io.caldav:1.10.0.201704300110]
at com.github.sardine.impl.SardineImpl.list(SardineImpl.java:386)[224:org.openhab.io.caldav:1.10.0.201704300110]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:248)[224:org.openhab.io.caldav:1.10.0.201704300110]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:135)[224:org.openhab.io.caldav:1.10.0.201704300110]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)[105:org.eclipse.smarthome.core.scheduler:0.9.0.201704291826]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573)[105:org.eclipse.smarthome.core.scheduler:0.9.0.201704291826]
any idea what could cause this error?
caldavio.cfg
caldavio:openhab:url=http://192.168.1.50/baikal/cal.php/calendars/openhab/openhab/
caldavio:openhab:username=openhab
caldavio:openhab:password=openhab
caldavio:openhab:reloadInterval=2
caldavio:openhab:preloadTime=20000
caldavCommand.cfg
caldavCommand:readCalendars=openhab
caldavPersonal.cfg
caldavPersonal:usedCalendars=openhab
