OK sorry the no was mean to be on.
Here are my binding configs:
CaldavIO
caldavio:AJ:url=https://p42-caldav.icloud.com:443/13xxx3642/calendars/086xxx6-1a0b-4301-a99d-5c5ebbcc5079/
caldavio:AJ:username=xxx@xxx.com.au
caldavio:AJ:password=mypassword
caldavio:AJ:reloadInterval=30
caldavio:AJ:preloadTime=2000
caldavio:AJ:disableCertificateVerification=false
caldavio:timeZone=Australia/Adelaide
CaldavPersonal
caldavPersonal:usedCalendars=AJ
items
alendarName1 "Up Next [%s]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:1 value:NAME" }
DateTime CalendarTimeStart1 "Starts [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:1 value:START" }
DateTime CalendarTimeEnd1 "Ends [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:1 value:END" }
//String CalendarAt1 "At [%s]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:1 value:PLACE" }
String CalendarName2 "Coming up [%s]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:2 value:NAME" }
DateTime CalendarTimeStart2 "Starts [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:2 value:START" }
DateTime CalendarTimeEnd2 "Ends [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:2 value:END" }
String CalendarName3 "Later [%s]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:3 value:NAME" }
DateTime CalendarTimeStart3 "Starts [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:3 value:START" }
DateTime CalendarTimeEnd3 "Ends [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:3 value:END" }
String CalendarName4 "Later [%s]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:4 value:NAME" }
DateTime CalendarTimeStart4 "Starts [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:4 value:START" }
DateTime CalendarTimeEnd4 "Ends [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:4 value:END" }
//String CalendarAt4 "At [%s]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:4 value:PLACE" }
String CalendarName5 "Later [%s]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:5 value:NAME" }
DateTime CalendarTimeStart5 "Starts [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:5 value:START" }
DateTime CalendarTimeEnd5 "Ends [%1$ta, %1$te %1$tb %1$tl:%1$tM%1$tp]" <calendar> { caldavPersonal="calendar:AJ type:EVENT eventNr:5 value:END" }
org.ops4j.pax.logging.cfg
# caldav_personal
log4j2.logger.caldav_personal.name = org.openhab.binding.caldav_personal
log4j2.logger.caldav_personal.level = TRACE
log4j2.logger.caldav_personal.additivity = false
log4j2.logger.caldav_personal.appenderRefs = caldav_personal
log4j2.logger.caldav_personal.appenderRef.caldav_personal.ref = caldav_personal
log4j2.appender.caldav_personal.name = caldav_personal
log4j2.appender.caldav_personal.type = RollingRandomAccessFile
log4j2.appender.caldav_personal.fileName = /var/log/openhab2/caldav_personal.log
log4j2.appender.caldav_personal.filePattern = /var/log/openhab2/caldav_personal.log.%i
log4j2.appender.caldav_personal.immediateFlush = true
log4j2.appender.caldav_personal.append = true
log4j2.appender.caldav_personal.layout.type = PatternLayout
log4j2.appender.caldav_personal.layout.pattern = %d{dd-MMM-yyyy HH:mm:ss.SSS} [%-5.5p] [%-50.50c] - %m%n
log4j2.appender.caldav_personal.policies.type = Policies
log4j2.appender.caldav_personal.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.caldav_personal.policies.size.size = 100MB
log4j2.appender.caldav_personal.strategy.type = DefaultRolloverStrategy
sample log
09-Jan-2018 22:18:38.377 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - calendar reloaded: AJ
09-Jan-2018 22:18:38.378 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - No events found in event cache for item 'CalendarTimeStart2'. Attempting to load from calendar.
09-Jan-2018 22:18:38.379 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeStart2, setting to UNDEF
09-Jan-2018 22:18:38.380 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarName3, setting to UNDEF
09-Jan-2018 22:18:38.383 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeStart1, setting to UNDEF
09-Jan-2018 22:18:38.386 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarName4, setting to UNDEF
09-Jan-2018 22:18:38.389 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarName1, setting to UNDEF
09-Jan-2018 22:18:38.391 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarName2, setting to UNDEF
09-Jan-2018 22:18:38.392 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeStart5, setting to UNDEF
09-Jan-2018 22:18:38.394 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeStart4, setting to UNDEF
09-Jan-2018 22:18:38.395 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarName5, setting to UNDEF
09-Jan-2018 22:18:38.397 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeStart3, setting to UNDEF
09-Jan-2018 22:18:38.398 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeEnd4, setting to UNDEF
09-Jan-2018 22:18:38.399 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeEnd5, setting to UNDEF
09-Jan-2018 22:18:38.401 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeEnd1, setting to UNDEF
09-Jan-2018 22:18:38.402 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeEnd2, setting to UNDEF
09-Jan-2018 22:18:38.403 [DEBUG] [hab.binding.caldav_personal.internal.CalDavBinding] - no event found for CalendarTimeEnd3, setting to UNDEF
Even though I have set TRACE it seems to be showing DEBUG.
I have all the ICS files in etc/caldav/AJ
I have tried clearing the cache and temp files but I recall there might be cache in the karaf database - havent worked out how to purge this.
Hope this helps explain the prob a bit better.
