Hi all,
I installed both of the the CalDav (Personal and Command) extensions in OpenHab2, added a Google Calendar MyCalendar and a daily event. Then I adjusted the
caldavPersonal.cfg
caldavPersonal:usedCalendars=MyCalendar
and the
caldavio.cfg
caldavio:MyCalendar:url=https://apidata.googleusercontent.com/caldav/v2/MY-CALENDAR-ID@group.calendar.google.com/events
caldavio:MyCalendar:username=GOOGLE-ACCOUNT-USERNAME
caldavio:MyCalendar:password=GOOGLE-ACCOUNT-PASSWORD
caldavio:MyCalendar:reloadInterval=5
caldavio:MyCalendar:preloadTime=5
caldavio:MyCalendar:disableCertificateVerification=true
caldavio:MyCalendar:charset=UTF-8
For the url I tried the already deprecated one and the new one (see above). For my google account I do not use two factor authentication.
Then I created items
String CalDav_MyCalendar "Termin [%s]" <calendar> { caldavPersonal="calendar:MyCalendar type:EVENT eventNr:1
value:NAME" }
and a sitemap entry
Text item=CalDav_MyCalendar label="Termin"
The item is also show in the sitemap. When I checked the logs, I saw for long time, there “charset” couldn’t be parsed, that was, because I forgot to suffix it with “caldavio:MyCalendar:”. For that reason, I stopped openhab, cleaned cache and rebooted.
But that didn’t solve the issue, too.
When I call my google calendar from the browser by copying the url I only get the message “Login required”. No clue, if something like that also comes up when CalDav tries to connect.
Hopefully you can help me to get the addon run, because it’s something I’m looking for longer times now.
Thanks and kind regards,
Dirk
