Anyway, thanks for your help! I will keep testing and changing configuration (I’m planning adding another calendar), I’ll post my solution here, hope it helps someone!
Now when I restarted OH, got this exception. Does anyone know what this means?
2018-09-08 14:00:22.172 [WARN ] [caldav.internal.job.EventReloaderJob] - Cannot load events for file: etc/caldav/openhab/72siaemvc2oXXXXXXXXXXXXX_google_com.ics
net.fortuna.ical4j.data.ParserException: Error at line 1:Unexpected end of file
at net.fortuna.ical4j.data.CalendarParserImpl.nextToken(CalendarParserImpl.java:568) [228:org.openhab.io.caldav:1.13.0.M3]
at net.fortuna.ical4j.data.CalendarParserImpl.assertToken(CalendarParserImpl.java:420) [228:org.openhab.io.caldav:1.13.0.M3]
at net.fortuna.ical4j.data.CalendarParserImpl.skipNewLines(CalendarParserImpl.java:490) [228:org.openhab.io.caldav:1.13.0.M3]
at net.fortuna.ical4j.data.CalendarParserImpl.assertToken(CalendarParserImpl.java:457) [228:org.openhab.io.caldav:1.13.0.M3]
at net.fortuna.ical4j.data.CalendarParserImpl.parse(CalendarParserImpl.java:111) [228:org.openhab.io.caldav:1.13.0.M3]
at net.fortuna.ical4j.data.CalendarBuilder.build(CalendarBuilder.java:198) [228:org.openhab.io.caldav:1.13.0.M3]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:339) [228:org.openhab.io.caldav:1.13.0.M3]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:100) [228:org.openhab.io.caldav:1.13.0.M3]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [100:org.eclipse.smarthome.core.scheduler:0.10.0.oh240M3]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [100:org.eclipse.smarthome.core.scheduler:0.10.0.oh240M3]
The type was not UPCOMING, but EVENT, which should be good for my case, but it didn’t really worked. Changing it to UPCOMING, solved this problem
