I need to set battery current on a battery solar inverter with different charging current setpoint values.
items
Switch IBAT "I BAT" <battery> (Studer) {autoupdate="false"}
Number IBAT_SW "I BAT SW [%.0f A]" <batterylevel> (Studer)
influx presistence memorize current setpoint value
IBAT_SW : strategy = everyChange, everyUpdate
sitemaps
Switch item=IBAT label="I BAT SET" mappings=[ON="SET"] visibility=[IBAT==OFF]
Setpoint item=IBAT_SW minValue=2.0 maxValue=50.0 step=1.0
rules
rule "IBAT set"
Item IBAT received command ON
executeCommandLine("python@@/etc/openhab2/scripts/ibatset.py")
This executes python script once switch IBAT has been pressed, but without transfer of setpoint value to the batset.py script.
How can be transfered also script parameter value together with script calling ?
Solution with lot of scripts with different SW values is posssible, but terrible.
Thanks.
