Can Harmony Remote control any of your openHAB devices?
the first Thing will work! Thanks
No I want to mute my Harmony with a Item.
So I made a Item with this;
String HarmonyHubMute “mute” { harmonyhub=“>[press:Samsung-Verstarker:MUTE]” }
But when I Put mute in the Body from the Rest API than the Item will change bute no mute :frowning:
When i use the Item “harmonyhub_device_Wohnzimmer_25713496_buttonPress” with the Body mute it will work.
I want to use the Desiger but it dosen´t work to, I use the Openhab2 on a PI. When i chose the Folder it doesen´t work.
I think the Problem is the missing config Folder in Verison 2.
For OH 2 you must use ESH Designer.
i have a Problem with a PowerOff rule.
rule "PowerOff_Amazon"
    Item Harmony_Hub.state.toString() changed from "Amazon" to "PowerOff")
    sendHttpGetRequest("http://192.168.188.74/config/xmlapi/statechange.cgi?ise_id=64056&new_value=1")
    sendHttpGetRequest("http://192.168.188.74/config/xmlapi/statechange.cgi?ise_id=63013&new_value=aus")
My first try doesn´t Work too…
    Item Harmony_Hub changed
    var String HarmonyState = Harmony_Hub.state.toString()
    if (HarmonyState changed from "Amazon" to "PowerOff"))
Thanks for Help…
Lars
The trigger on your first try is correct. The second one is incorrect.
The the first try’s mistake is the if statement. Assuming you have persistence configured on the item you need to do something like the following
if(Harmony state != Harmony_Hub.previousState.state)
I just tried in the above from memory so I might have it a little wrong.
I highly recommend using Designer and <ctrl><space> to help check and discover correct rule syntax as you type.
Thanks for help. But both of my Rules doesn’t work.
Yes the Syntax but with the Desinger… I don’t Unterstand them. With Working Rules the Desinger habe Problems. Can you give me a Working Rule for my example than i have a example for the Syntax.
I’m using the HUE Emulation to control openHAB from Harmony Hub and Amazon Echo (Alexa)
This might be less flexible but it works fine.
I can use the Smart Home Buttons on the Harmony Remote
and trigger the same items from Alexa.
I can post my configuration if wanted?
Sitemap (part)
	Frame label="Hue Emulation Harmony" {
		Switch item=huee_audio_radio
		Switch item=huee_audio_mp3
		Switch item=huee_tv_schauen
		Switch item=huee_fire_tv_schauen
		Switch item=huee_kodi_schauen
		Switch item=huee_apple_tv_schauen
		Switch item=huee_ps4_tv_schauen
		Switch item=huee_fire_tv_schauen_beamer
		Switch item=huee_kodi_schauen_beamer
		Switch item=huee_apple_tv_schauen_beamer
		Switch item=huee_ps4_tv_schauen_beamer
		Switch item=huee_harmony_aus
Items
// Hue Emulation Items
//Switch  TestSwitch1     "Kitchen Switch" [ "Switchable" ]
//Switch  TestSwitch2     "Bathroom" [ "Lighting" ]
//Dimmer  TestDimmer3     "Hallway" [ "Lighting" ]
//Number  TestNumber4     "Temperature Set Point" [ "TargetTemperature" ]
// Audio
Switch huee_audio_radio "Radio" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
Switch huee_audio_mp3 "Musik" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
// TV
Switch huee_tv_schauen "Fernseher" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
Switch huee_fire_tv_schauen "Fire TV" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
Switch huee_kodi_schauen "Kino" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
Switch huee_apple_tv_schauen "Apple TV" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
Switch huee_ps4_tv_schauen "Playstation" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
// Beamer
Switch huee_fire_tv_schauen_beamer "FireTV auf dem Beamer" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
Switch huee_kodi_schauen_beamer "grosses Kino" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
Switch huee_apple_tv_schauen_beamer "Apple TV auf dem Beamer" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
Switch huee_ps4_tv_schauen_beamer "Playstation auf dem Beamer" (gEG_WHU_HUEE_Harmony) [ "Switchable" ]
// Aus
Switch huee_harmony_aus "Wohnzimmer" (gEG_WHU_HUEE_Harmony_inv) [ "Switchable" ]
Rules zur Harmony (no init yet, first attempts may fail after restarting openHAB)
import java.util.concurrent.locks.Lock
import java.util.concurrent.locks.ReentrantLock
var Lock lock = new ReentrantLock()
    rule "HUEE_WHZ_Harmony_Scene"
            Item  gEG_WHU_HUEE_Harmony changed
    	lock.lock()
	   	try {
	   	  Thread::sleep(250) // needed ? give persistence time to populate lastUpdate
	      gEG_WHU_HUEE_Harmony.members.forEach[ currItem |
				val itemName = currItem.name
		        val scene = currItem.label.toString()
		        //pushNotification("WHZ HUEE Harmony Trigger"," nameOfItem <"+itemName+"> scene<"+scene+">")
		        logInfo("WHZ HUEE Harmony Trigger"," nameOfItem <"+itemName+"> scene<"+scene+"> state<"+currItem.state.toString()+">")
		        if (currItem.state == ON)
					if("huee_audio_radio".equals(itemName)) {
						logInfo("HarmonyHubWohnzimmer_CurrentActivity", "Radio")
						sendCommand("HarmonyHubWohnzimmer_CurrentActivity", "Radio")
					} else if ("huee_audio_mp3".equals(itemName)) {
						logInfo("HarmonyHubWohnzimmer_CurrentActivity", "Kodi - Audio")
						sendCommand("HarmonyHubWohnzimmer_CurrentActivity", "Kodi - Audio")
					} else if ("huee_tv_schauen".equals(itemName)) {
						logInfo("HarmonyHubWohnzimmer_CurrentActivity", "Fernsehen")
						sendCommand("HarmonyHubWohnzimmer_CurrentActivity", "Fernsehen")
					} else if ("huee_fire_tv_schauen".equals(itemName)) {
						logInfo("HarmonyHubWohnzimmer_CurrentActivity", "Fire TV - TV")
						sendCommand("HarmonyHubWohnzimmer_CurrentActivity", "Fire TV - TV")
					} else if ("huee_kodi_schauen".equals(itemName)) {
						logInfo("HarmonyHubWohnzimmer_CurrentActivity", "Kodi - TV")
						sendCommand("HarmonyHubWohnzimmer_CurrentActivity", "Kodi - TV")
	    } catch (Exception e) {
	      logInfo("HUEE_WHZ_Harmony_Scene", "exception: " + e)
	    } finally {
	    	lock.unlock()
    rule "HUEE_WHZ_Harmony_Scene_inv"
            Item  gEG_WHU_HUEE_Harmony_inv changed
    	lock.lock()
	   	try {
	   	  Thread::sleep(250) // give persistence time to populate lastUpdate
	      gEG_WHU_HUEE_Harmony_inv.members.forEach[ currItem |
		        logInfo("WHZ HUEE Harmony Trigger INV"," nameOfItem <"+itemName+"> scene<"+scene+"> state<"+currItem.state.toString()+">")
		        if (currItem.state == OFF)
		        	 if ("huee_harmony_aus".equals(itemName)) {
						sendCommand("HarmonyHubWohnzimmer_CurrentActivity", "PowerOff")
	      logInfo("HUEE_WHZ_Harmony_Scene_inv", "exception: " + e)
	    } finally {
	    	lock.unlock()
    rule "HUEE_WHZ_Harmony_Activity"
            Item  HarmonyHubWohnzimmer_CurrentActivity received command
    		logInfo("WHZ HUEE HUEE_WHZ_Harmony_Activity Trigger"," CurrentActivity <"+HarmonyHubWohnzimmer_CurrentActivity.state.toString()+">")
    		if ("PowerOff".equals(HarmonyHubWohnzimmer_CurrentActivity.state.toString())) {
                        // reset activity buttons so they can be turned on
    			sendCommand(gEG_WHU_HUEE_Harmony,OFF)
    			sendCommand(gEG_WHU_HUEE_Harmony_inv, OFF)
    		} else {
    			sendCommand(gEG_WHU_HUEE_Harmony_inv,ON)
Typing from my phone so the following probably has errors.
In order to test what the Item state changed from you must have persistence set up using something other than MapDB.
    if(Harmony_Hub.state =="Power off" && Harmony_Hub.previousValue(true).State == "Amazon"){
        // Do stuff
End
thanks for Help!! Here ist the Rule that works:
rule "PowerOff"
 if (Harmony_Hub.state == "PowerOff" && previousState == "Fernseher")
    sendHttpGetRequest("http://192.168.188.30/web/powerstate?newstate=0")
My hope is still to get the neeo remote from kickstarter. there is also a REST-API available :slight_smile:
I orderd one remote one and a half year ago …
But it seams the delivery-date is very close. to who it may interesting take a look at www.neeo.com and read there blog
