If i have unstable internet connection can HTTP binding cause to crash MQTT binding?
Fatal transport error: java.util.concurrent.TimeoutException
Here is errors after that mqtt stops working:
2017-03-13 01:48:54.322 [ERROR] [org.openhab.io.net.http.HttpUtil ] - Fatal transport error: java.net.NoRouteToHostException: No route to host
2017-03-13 01:48:54.353 [ERROR] [ab.binding.http.internal.HttpBinding] - No response received from 'http://192.168.1.12/simread?clear=1'
2017-03-13 01:50:42.037 [INFO ] [eclipse.smarthome.model.script.Meteo] - Send
**2017-03-13 01:50:49.302 [ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.TimeoutException**
2017-03-13 01:50:49.328 [INFO ] [eclipse.smarthome.model.script.Meteo] - Wunderground.com - null
2017-03-13 01:52:59.505 [ERROR] [org.openhab.io.net.http.HttpUtil ] - Fatal transport error: java.net.NoRouteToHostException: No route to host
2017-03-13 01:52:59.519 [ERROR] [ab.binding.http.internal.HttpBinding] - No response received from 'http://192.168.1.12/simread?clear=1'
2017-03-13 01:57:06.224 [ERROR] [org.openhab.io.net.http.HttpUtil ] - Fatal transport error: java.net.NoRouteToHostException: No route to host
2017-03-13 01:57:06.248 [ERROR] [ab.binding.http.internal.HttpBinding] - No response received from 'http://192.168.1.12/simread?clear=1'
2017-03-13 01:57:10.167 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-03-13 01:57:10.208 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-03-13 01:57:10.233 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-03-13 01:57:10.251 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-03-13 01:57:10.274 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-03-13 01:57:10.309 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-03-13 01:57:10.332 [ERROR] [n.mqtt.internal.MqttMessagePublisher] - Error publishing message: Too many publishes in progress
2017-03-13 02:08:56.966 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
Unexpected error (6)
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:115)[214:org.openhab.io.transport.mqtt:1.10.0.201702140757]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
2017-03-13 02:08:56.971 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'oh2agdisk' was lost: Unexpected error : ReasonCode 6 : Cause : Unknown
2017-03-13 02:08:56.973 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'oh2agdisk'
