Is it possible to install the upnp feature using addons.cfg
? I have a couple bindings that I put in addons
that have a dependency on upnp. I’m getting tired of installing the upnp feature from the console every time I upgrade to a new snapshot.
Easiest way would be to add SONOS or WeMo Binding to your addons.cfg, even not using them.
Good point! I hadn’t thought of that.
That sounds like a bug that should be fix for those bindings. They should install the features they need right?
Not a bug – a feature!
When you put bindings in addons, their dependencies are not installed automatically (the deps are defined in features.xml, which doesn’t exist for binding in addons).
I am wondering if you could create a custom features.xml
and deploy it together with your *.jar
… I will check and report back
OK, well I guess users who are adding bindings to the addons folders should know what they are getting into.
yep, but esp with bindings under development it could help to make installation easier
