#Background:
I have been running a basic OpenHAB server for 6 months odd with 5 Lifx Lights and a load of rules to turn on/off the lights depending on who is awake/in/out of the house. We started getting issues with lights randomly coming on/off as the rules got complex and the console logging was/is hard to get enough info to debug (also limited in size and often gone by the time I get time to look) so I have decided to start again but this time logging all of the commands and states into a MySQL DB.
#What I have managed:
I have managed to install and setup a MySQL DB, install the āMySQL Persistanceā (persistance-mysql - 1.10.0) Add-on from Paper-UI and get it to log all items state changes using the following āmysql.persistā Persistence file:
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
everyMinute : "0 * * * * ?"
every5Minutes : "0 */5 * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
* Each line in this section defines for which item(s) which strategy(ies) should be applied.
* You can list single items, use "*" for all items or "groupitem*" for all members of a group
* item (excl. the group item itself).
Items {
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyUpdate, restoreOnStartup
The console thew some errors (and still seems to now and then) that:
21:45:56.097 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
21:45:56.116 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query '##ITEM NAME##'.
21:45:56.119 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query '##GROUP NAME##'.
... etc
BUT then I have tables like āItemsā that seems to contain a list of all items that have had a value change since the persistent stuff was setup and a corresponding table āItem1ā for example that has the time and a string representing the new valueā¦
#Problem:
This is great (or a good start) but I canāt find any information on how to take this further and push my own messages from the rules into my own tables?
So can someone point me in the right directionā¦ I am kind of assuming itās possible! If this assumption is wrong I guess can someone break the bad news and maybe offer an alternative way of permanently logging what functions ran at what time and any information and data I want to dump outā¦
