I have tried to discover a Schlage Link Power Socket using the Z wave binding. The binding reports that its is an unknown device. The xml file that is generated has a bunch of things in there but the manufacturer, device and type are all reported as ox7FFFFF.
<?xml version="1.0"?>
-<node>
<homeId>0xc186a966</homeId>
<nodeId>17</nodeId>
<version>3</version>
<manufacturer>0x7fffffff</manufacturer>
<deviceId>0x7fffffff</deviceId>
<deviceType>0x7fffffff</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
-<nodeInformationFrame>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_ALL</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map"/>
-<endpoints class="concurrent-hash-map">
-<entry>
<int>0</int>
-<endPoint>
-<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_POWER_SWITCH_BINARY</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
-<supportedCommandClasses class="concurrent-hash-map">
-<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
-<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
-<entry>
-<COMMAND__CLASS__SWITCH__BINARY>
<version>0</version>
<versionSupported>0</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
-<entry>
-<COMMAND__CLASS__SWITCH__ALL>
<mode>SWITCH_ALL_INCLUDE_ON_OFF</mode>
</COMMAND__CLASS__SWITCH__ALL>
</entry>
-<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
-<COMMAND__CLASS__BASIC>
</COMMAND__CLASS__BASIC>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2019-10-14 01:56:11.435 UTC</lastReceived>
</node>your code goes here
Looking at the Z wave database, there is a similar switch which appears to be manufactured by Wintop and is also sold under the brand DHS pty. Is there a way to manually configure this device using the information from the database? I also have a problem discovering two Heiman smoke detectors which also appear to be in the database. Other devices are working ok.
I am using a recent snapshot of the 2.5 Z wave binding.
