Can i pass items as arguments to rule?
Ok, that seems to find the item. Now it throws another error :slight_smile:
(I’m testing the script by updating the temperature value manually in MQTT explorer)
Script execution of rule with UID 'thermostat' failed: org.graalvm.polyglot.PolyglotException: TypeError: invokeMember (getItem) on org.openhab.core.internal.items.ItemRegistryImpl@1a5a5b63 failed due to: Cannot convert '[object Object]'(language: JavaScript, type: O) to Java type 'java.lang.String': Invalid or lossy primitive coercion.
EDIT:
I added a few lines of logging, and the script reads the state correctly.
That means they are correctly passed onto the second script.
// Log the state of KNX items
var valveState = heatingValve.state.toString();
var contactState = heatingContact.state.toString();
// Log the states
console.log("Heating Valve State: " + valveState);
console.log("Heating Contact State: " + contactState);
INFO	org.openhab.automation.script.ui.thermostat	Heating Valve State: OFF
INFO	org.openhab.automation.script.ui.thermostat	Heating Contact State: OFF
if (hvacMode == "COMFORT") {
  if (temperature < setpointComfort){
    items.getItem(heatingValve).sendCommand("ON");
    items.getItem(heatingContact).sendCommand("ON");
    console.log("Temperature is below the comfort level. Heating valve turned ON.");
  else if (temperature > (setpointComfort + hysteresis)) {
    items.getItem(heatingValve).sendCommand("OFF");
    items.getItem(heatingContact).sendCommand("OFF");
    console.log("Temperature is above the comfort range. Heating valve turned OFF.");
else if (hvacMode == "STANDBY") {
  if (temperature < setpointStandby){
    console.log("Temperature is below the standby level. Heating valve turned ON.");
  else if (temperature > (setpointStandby + hysteresis)) {
    console.log("Temperature is above the standby range. Heating valve turned OFF.");
else {}
Sorry for all my questions :slight_smile: i’m still getting used to the language.
Just checking whether you are passing the correct key names into the script? Ie you’re passing in a key of heatingValve, but accessing a key of valve
var parameter = {
          'temperature': temp,
          'hvacMode': mode,
          'setpointComfort': comforttemp,
          'setpointStandby': standbytemp,
          'heatingValve': valve,
          'heatingContact': contact,
          'hysteresis': 0.3
var heatingValve = ctx['valve'];
As mentioned, in your script var heatingValve should already by defined, although I prefer to access keys via ctx[‘key’] so I keep track of where they’re coming from. In this case, you’re overwriting var heatingValve with a non existent key
I got it!! :sweat_smile:
The item was indeed already defined, so there was no need for the getItem() function.
Removed that, cleaned up the code and now it works.
console.log("running thermostat script")
var setPoint = 18;
  setPoint = setpointComfort;
  setPoint = setpointStandby;
else {}
if (temperature < setPoint){
  heatingValve.sendCommand('ON');
  heatingContact.sendCommand('ON');
else if (temperature > (setPoint + hysteresis)) {
  heatingValve.sendCommand('OFF');
  heatingContact.sendCommand('OFF');
Thank you for all the help! :grin:
Glad you got it to work.
I have been waiting to do this for a while and your question made me finally look at how to do it and it worked.
HI everyone,
I integrated the script and the rules into my production environment, but there is something wrong.
The script keeps sending “ON” and “OFF” to the knx devices, even when the state is already on or off.
Also i can’t access my rules/scripts/schedule or console log from the UI…
It sounds like it is in a loop and slowing the server down.
I have done that before as well…annoying.
I restart the openhab and quickly disable the rule.
You have to be quick. You can do it via the web page or the console-cli by running:
rules:disable thermostat
You probably can get to the console-cli but it might be really slow (depending on what you are running it on).
Good luck.
Please post the whole script
The script didn’t appear to be in a loop. The load on the Raspberry pi was only 20-30% CPU usage. Things and Items still worked and console was accessible.
The pages became avaiIable again after i deleted everything in the cache and tmp folder, and restarted the docker container. It seems like there’s a bug somewhere :slight_smile:
I adjusted the script, and now it’s sending the command only on state change:
//console.log("running thermostat script")
var setPoint = 18;
else {}
  if(heatingValve.state == "OFF"){
  if(heatingContact.state =="OFF"){
  //console.log("Temperature is below the comfort level. Heating valve turned ON.");
  if(heatingValve.state == "ON"){
  if(heatingContact.state =="ON"){
  //console.log("Temperature is above the comfort range. Heating valve turned OFF.");
This is the error:
Furthermore, I wouldn’t pass the whole item object to the other rule. Just the name of the item as a string.
Then you can continue in the rule like this:
items[heatingValve].state
items[heatingValve].sendCommand('OFF');`
You can make this shorter:
var sNewState = (temperature < setPoint)?"ON":"";
if (temperature > (setPoint + hysteresis)) sNewState = "OFF";
if sNewState != "" {
  items[heatingValve].sendCommandIfDifferent(sNewState);
  items[heatingContact].sendCommandIfDifferent(sNewState);
That is indeed much cleaner :slight_smile:
I adjusted all the rules and the script:
var temp = parseFloat(items["HvacLiving_LivingTemperature"].state);
var mode = items["HvacLiving_LivingHVACmode"].state.toString();
var standbytemp = parseFloat(items["HvacLiving_LivingStandbyTemperature"].state);
var comforttemp = parseFloat(items["HvacLiving_LivingComfortTemperature"].state);
var valve = "KNX_Device_DO3_cv_valve_ground_floor";
var contact = "KNX_Device_DO3_cv_heat";
var parameter = {
  'hvacMode': mode,
  'hysteresis': 0.3
rules.runRule('thermostat', parameter);
var setPoint = 18;
else {}
  sNewState = "OFF";
if (sNewState != "") {
I also found a new flaw in my plan i think.
The “CV heat contact” shouldn’t be turned off if another room is still warming up.
I think i’ll remove it in Openhab for now and connect it to all the valves in ETS.
