Can I use the case command in rules for actions depending on weekdays?
  • Platform information:
    • Hardware: Intel NUC
    • OS: Windows 10
    • Java Runtime Environment: jdk1.8.0 191
    • openHAB version: 2.3.0
08
I tried to program a rule using the case command but failed :frowning: plenty of errors. As I am not an experienced programmer I ask here for a hint.
Thnks
Hi Thomas
switch - case logic is possible. But your used syntax looks wrong.
One example can be found here:
Hope that helps.
Regards
Stefan
I’ll give you a start, the rest is up to you :wink:
rule "TagabhƤnging"
Channel ā€˜astro:sun:local:set#event’ triggered START
switch (now.getDayOfWeek){
case 1: Waschen.sendCommand(ON)
case 2:
case 3:
More info about switch: switch expression
Good luck
Great, thanks, that’s it!
Hi Laurens
I have one additional question: Where can I find the possible values for the ā€œget.ā€ function?
e.g. are the get.DayOfWeek values from 1 to 7 and is 1 Monday?
Here you can find it
Thanks Laurens. I am growing slowly into it. There are so many object, etc. to learn.
Best regards
Thomas
Dear Thomas
Don’t worry about that. :slight_smile: I’m working now since more than 3 years with openHAB and I’m still a newbie so to say. It all depends what you would like to achieve and how. Some things are more easy than others.
So happy learning with openHAB :ok_hand:
Cheers
Stefan
