Hi, I have the problem, that if I turn on the Amazon Music switch to ON it will change back to OFF. also I will get the error, when I select my playlist. I have replicated this problem with the last snapshot 3.2.0, Milestone 3.2.0.M4 and Stable 3.1.0.
12:19:23.868 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@5c2fdaf3': POST url 'https://alexa.amazon.de/api/cloudplayer/queue-and-play?deviceSerialNumber=G2A0QU06748607AH&deviceType=A7WXQPH584YP&mediaOwnerCustomerId=A1PRGVPQ6HYOE1&shuffle=false' failed: Bad Request
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.de/api/cloudplayer/queue-and-play?deviceSerialNumber=G2A0QU06748607AH&deviceType=A7WXQPH584YP&mediaOwnerCustomerId=A1PRGVPQ6HYOE1&shuffle=false' failed: Bad Request
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:691) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.playAmazonMusicPlayList(Connection.java:1309) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.handleCommand(EchoHandler.java:481) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor66.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy314.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor65.invoke(Unknown Source) ~[?:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
12:20:08.274 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'EchoWohnzimmer_AmazonMusic' received command ON
12:20:08.277 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'EchoWohnzimmer_AmazonMusic' predicted to become ON
12:20:08.283 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'EchoWohnzimmer_AmazonMusic' changed from OFF to ON
12:20:09.890 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'EchoWohnzimmer_AmazonMusic' changed from ON to OFF
