Miami_Dabs
(Dwayne Gonzalez)
July 16, 2016, 4:53am
#1
so i am following this article Garage door opener and i am having a bit of difficulty.
i have mqtt up and running.
through Putty, i can publish a message to the esp01 module, and it receives it and activates the relay as it shouold.
the open.close sensor is working and i can see it in Putty receiving messages.
the problem is the status of the door is not populating in the site map.
and when i press Go, the esp01 does not receive the message.
i believe i have a problem with the sitemap/items coding. something is not matching up.
here are some pictures
Miami_Dabs
(Dwayne Gonzalez)
July 16, 2016, 4:58am
#2
when i click on the button on the sitemap, it shows relay1 received. but it is not transmitting to the esp01 module
rlkoshak
(Rich Koshak)
July 16, 2016, 3:48pm
#3
It looks like either your Item MQTT configuration is not correct or your MQTT addon is not properly configured.
Miami_Dabs
(Dwayne Gonzalez)
July 16, 2016, 8:36pm
#4
it was my openhab.cfg file that lookslike it was not configured properly. i got it to work now. howeber i am experiencing another problem with my esp01 module.
it does not auto start init.lua and when i connect to esplorer it says cant autodetect firmware.
sihui
(SiHui)
July 17, 2016, 3:04pm
#5
Which firmware are you using? Nodemcu?
Try connecting with 115200 instead of 9600 baud.
Miami_Dabs
(Dwayne Gonzalez)
July 17, 2016, 9:19pm
#6
I have tried that. I flashed the master bin.
