- Platform information:
- Hardware: Intel core i5 3.20Ghz 8GB RAM
- OS: Windows home server 2011
- Java Runtime Environment: ZULU
- openHAB version: 2.
- Issue of the topic:
New to open hab after successfully installing and accessing the webpage I am now trying to install add ons using the paper UI. they just spin and never say installed. although In the log there are addons that do say installed? also I see in the log the milight add on is still doing things. but I can not see that it is installed or search for things.
Thanks in advance
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
[2019-01-01 11:36:21.173 [thome.event.ExtensionEvent] - Extension ‘package-standard’ has been installed.
2019-01-01 11:36:29.906 [thome.event.ExtensionEvent] - Extension ‘ui-homebuilder’ has been installed.
2019-01-01 11:36:29.908 [thome.event.ExtensionEvent] - Extension ‘ui-basic’ has been installed.
2019-01-01 11:36:29.909 [thome.event.ExtensionEvent] - Extension ‘ui-habpanel’ has been installed.
2019-01-01 11:36:29.909 [thome.event.ExtensionEvent] - Extension ‘ui-paper’ has been installed.
2019-01-01 11:48:11.207 [thome.event.ExtensionEvent] - Extension ‘binding-amazonechocontrol’ has been installed.
2019-01-01 11:49:02.857 [thome.event.ExtensionEvent] - Extension ‘binding-rfxcom’ has been installed.
2019-01-01 11:49:57.161 [thome.event.ExtensionEvent] - Extension ‘binding-milight’ has been installed.
2019-01-01 11:49:57.693 [home.event.InboxAddedEvent] - Discovery Result with UID ‘milight:bridgeV6:F0FE6BC29810’ has been added.
2019-01-01 12:21:13.384 [thome.event.ExtensionEvent] - Extension ‘binding-network’ has been installed.
2019-01-01 12:42:40.633 [thome.event.ExtensionEvent] - Extension ‘package-standard’ has been installed.
2019-01-01 12:43:44.700 [thome.event.ExtensionEvent] - Extension ‘ui-homebuilder’ has been installed.
2019-01-01 12:43:44.709 [thome.event.ExtensionEvent] - Extension ‘binding-milight’ has been installed.
2019-01-01 12:43:44.710 [thome.event.ExtensionEvent] - Extension ‘ui-basic’ has been installed.
2019-01-01 12:43:44.710 [thome.event.ExtensionEvent] - Extension ‘binding-rfxcom’ has been installed.
2019-01-01 12:43:44.711 [thome.event.ExtensionEvent] - Extension ‘binding-network’ has been installed.
2019-01-01 12:43:44.711 [thome.event.ExtensionEvent] - Extension ‘binding-amazonechocontrol’ has been installed.
2019-01-01 12:43:44.712 [thome.event.ExtensionEvent] - Extension ‘ui-habpanel’ has been installed.
2019-01-01 12:43:44.712 [thome.event.ExtensionEvent] - Extension ‘ui-paper’ has been installed.
01 12:40:58.806 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-01-01 12:42:36.179 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to ‘50.9274,-1.3514’.
2019-01-01 12:42:39.069 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.85:8080
2019-01-01 12:42:39.071 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.85:8443
2019-01-01 12:42:39.610 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-01-01 12:43:44.254 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-01-01 12:43:44.288 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-01-01 12:43:44.653 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-01-01 12:43:45.019 [INFO ] [nal.protocol.MilightV6SessionManager] - Confirmation received for unsend command. Sequence number: 256
2019-01-01 13:13:45.306 [INFO ] [nal.protocol.MilightV6SessionManager] - Confirmation received for unsend command. Sequence number: 256
2019-01-01 13:13:46.866 [INFO ] [nal.protocol.MilightV6SessionManager] - Confirmation received for unsend command. Sequence number: 256
