I can not install any Voice TTS binding.
There is no Install button in Paper UI.
/Mike
/Mike
Don’t you have the Voice Tab under Addons? After installing a service there you can configure it under Configuration-System. Scroll down nearly to the end.
That’s weird. The order of those is different. You also have those two icons with squares in the upper left corner, which I don’t have. I guess you’re on a snapshot of OH2?
I suggest you open another thread regarding this faulty behaviour of PaperUI in the appropriate section.
